Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-08-2011 | 01:24 PM
  #901
Looked through this thread a decent amount and didn't really get a clear answer on what I was looking for. So, I have been running a olser P5XS for some time now with a J-P3 pipe which gets the job done, but I feel there is more than likely something better for it out there. I typically run a mediumish size track. What nova header/pipe combo is best for this motor? Thanks
cleblanc is offline
Old 03-08-2011 | 02:06 PM
  #902
teamlosi906's Avatar
I liked the 9853 pipe with the 021 header on mine.In a truggy
teamlosi906 is offline
Old 03-08-2011 | 02:10 PM
  #903
Just for the record, gonna be in a buggy. Thanks for the responses so far.
cleblanc is offline
Old 03-08-2011 | 04:48 PM
  #904
ntrain42's Avatar
Originally Posted by Maximo
I'll stick to my guns on this one boys...the LRP 30 has got nothin on a Picco 28 !
Ntrain if you got the cash, then buy one of my converted OS 28's... its a really badass MT engine, but it aint cheap !
OS 28? Which OS engine? The .28XZ Truggy comp engine? Spin start capable for the XXL?
The only OS engine I know of that is spinstart capable is the OS Max .30VG ES ABL motor, but I havent heard much on it compared to the Picco's and other higher quality engines.
ntrain42 is offline
Old 03-08-2011 | 10:25 PM
  #905
mblgjr's Avatar
For Buggy: 41021/9901
You should see a nice jump in fuel mileage and a smoother midrange pull compared to the JP3 (which SUCKS fuel).
mblgjr is offline
Old 03-08-2011 | 10:37 PM
  #906
houston's Avatar
You should see a nice jump in fuel mileage and a smoother midrange pull compared to the JP3 (which SUCKS fuel)./
it does on the 5 ports
seems to work decent on the 4 ports though
houston is offline
Old 03-09-2011 | 07:43 AM
  #907
PowerHouse's Avatar
The 5 ports have lower transfer timing and higher blowdown timing so the transfer ports will close sooner and the exhaust port remains open longer so the enigne will scavage differently from say the Plus 4 which has higher transfer timing and lower blowdown timing which means the transfer remain open longer and the exhaust closes sooner. The longer the blowdown timing, the longer the pipe needs to be and the opposite holds true for shorter blowdown.
Now where the Plus 4 excells over say the stock P5 is even though the blowdown timing is longer in the P5 than the Plus 4, the location of the ports in relation to the crank intake timing makes a difference. The Plus 4 ports are higher in relation therefore prefers and benefits more from the longer pipes than the P5 does with lower port to crank intake relation. The Plus 4 also has 3 case induction ports closer in size so the pressure is equalized more across the board where the P5 has 2 larger transfer induction areas and a smaller booster area so the velocity accellerates in the booster and slows down in the transfer areas creating a different chamber fill and a slightly different loop scavaging effect. It doesn't neccessarily mean it's a bad thing, just gives the engine different running and tuning characteristics.
There is definately a science when it comes to pairing pipes with engine designs and yes, most engine designs are close as far as overall timing specs but there is enough of a difference between them that certain pipes will excell on some and not fair as well with others. There are also some what I would call neutral pipes that work decent on just about any engine you throw them on but again may not be the best for it but it will run decent either way and get you in the ballpark.
PowerHouse is offline
Old 03-09-2011 | 09:35 PM
  #908
Default Desoto Racing - Novarossi
We will be attending the Psycho Nitro Blast this weekend in Georgia. If you need any setup help or have any questions please do not hesitate to stop by our pit area.
jdesoto is offline
Old 03-09-2011 | 09:48 PM
  #909
houston's Avatar
Awesome joaquin!
houston is offline
Old 03-11-2011 | 08:16 PM
  #910
New Nova engines are ballistic. The BTT & BTTS accelerate like they are launched from a rocket plus we are getting 12 minutes of runtime!!! Stay tuned for results from the first round of Qualifying at the PNB race in Georgia.
jdesoto is offline
Old 03-12-2011 | 01:52 AM
  #911
sounds great.
Which glowplug and pipe do you use in the BTT engine?
Are you running the BTT in both classes or do you use the bonito engine for truggy?
reel is offline
Old 03-12-2011 | 04:29 AM
  #912
chicky03's Avatar
Originally Posted by reel
sounds great.
C6gtc
41021/9901
Btt for buggy
Bonito for truggy
chicky03 is offline
Old 03-19-2011 | 10:07 PM
  #913
Guest
hey guys just picked up a new p5 for my d8t. Is it cool to run 30% right off the bat? manual says 25 max. What do you guys think. I used to run 30% last season with good results but I reall wanna prolong the life of this motor as much as possible. Any good avice?
Also I have a dynamite 053 hard anodized pipe but ppl are recommending the 086...any reason for this?
rctechuser015851 is offline
Old 03-19-2011 | 10:14 PM
  #914
houston's Avatar
youre fine to run 30% , they are shimmed for it for us americans
as far as pipes , what are you gonna be running it on?
truggy the 053mr will be just fine , buggy i would recommend and 086hs or if you can get the real deal a 9886/41021 , 2013 pipe also works great
houston is offline
Old 03-19-2011 | 10:19 PM
  #915
Ultraspeed84's Avatar
Does the BTT get better run time then the plus4? Most say they are not seeing much Diff from the BTT from the plus4.
Ultraspeed84 is offline
