Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-20-2016 | 10:26 AM
  #9031
Any tricks on getting a stubborn sleeve out of a block without damaging the sleeve ?
travertini is offline
Old 06-20-2016 | 11:07 AM
  #9032
Maximo's Avatar
Have to use heat.... set your toaster oven for 250 and give the engine a good 10 minutes to heat up...then use a clutchnut on the crankshaft and a plastic tie wrap thru the exhaust port....Many times castor oil residue glues the sleeve in place and requires a little heat to get loosened up
Maximo is offline
Old 06-20-2016 | 12:36 PM
  #9033
Thank u Maximo ! I have it halfway out but for sum reason the second half is really stuck,
Old 06-20-2016 | 03:07 PM
  #9034
lilstewie's Avatar
Default Nova 16802 Ceramic Bearing
Does anyone know if there is an aftermarket brand for this ceramic bearing? The size is 14x25.8x5. Asking for a friend of mine.
Thanks.
lilstewie is offline
Old 06-20-2016 | 04:51 PM
  #9035
bash bros's Avatar
Thanks.
Is this the one your looking for, for the Keep Off 4?
https://www.amainhobbies.com/tko-14x...mr1223/p384904
bash bros is offline
Old 06-20-2016 | 05:35 PM
  #9036
I believe Avid has them also
motoclay is offline
Old 06-21-2016 | 01:32 PM
  #9037
trax70 guy's Avatar
Default novarossi NVR08567-T11
piston and sleeve and rod
Manuals show the same #s for the mito7 and the bonita 7
Is this true ????????????
mine lacks a little comp Runs good but just looking to improve it Motor has
4 gls thu it Could pinch it but don,t know who to use ???
Suggestion please
thanks
trax70 guy is offline
Old 06-21-2016 | 01:49 PM
  #9038
bash bros's Avatar
Probably my fault from running the top end too lean but I tore my Elite 5 apart and noticed some of the plating looks worn through in a few spots around the transfer ports on the inside of the sleeve. The pinch zone is still good and has a nice shiny mirror finish and the engine still has good compression. But will this cause any problems?
Old 06-21-2016 | 02:54 PM
  #9039
lilstewie's Avatar
I don't think so. Nova shows it as a 14x25.8x5 not 6.
Old 06-21-2016 | 03:06 PM
  #9040
bash bros's Avatar
If it's for a Keep Off 4 I'm pretty sure that's the right bearing. 14x25.8x5.7x4.7 are the actual dimensions, the outer race is 5.7mm, the inner race is 4.7mm.
Old 06-22-2016 | 05:28 PM
  #9041
cczjordan's Avatar
Suggestion please
thanks
Yes, is the same thing.
cczjordan is offline
Old 06-24-2016 | 08:29 AM
  #9042
lilstewie's Avatar
Thanks guys. Apparently some of the (older?) manuals showed the wrong size.
Old 06-26-2016 | 02:27 AM
  #9043
whats the run time on a novarossi mito 4 with 9886 pipe and a 41001 header
geforce is offline
Old 06-26-2016 | 08:19 AM
  #9044
Jerm13's Avatar
Kind of a loaded question..... There are tons of things that play into run time. Ambient temp, humidity, fuel and nitro content, elevation, track conditions, drive train efficiency, clutch, carb inset, traction available with the correct tires installed on the car, pipe and header, and mostly how you drive it....
A fully broken in motor properly tuned for the weather and location, with the correct pipe and clutch on a car with the correct set-up, driven smoothly ( like most pro drivers) should make around 10 minutes. The same set-up with a normal person, will probably be around 8 1/2-9 minutes. All things being equal, minus the driver that is..
It would be safe to say 8-9 minutes.
Jerm13 is offline
Old 06-26-2016 | 11:47 AM
  #9045
Default Engine for Buggy
Looking to get a new engine soon for my MP9 and wanted to see everyone's opinion on the following choices:
Rex Legend 4
Rex Legend 7
PLUS .21-4BTT/A
BONITO .21-7XLB
I currently have the following pipes to go with them:
werks 2058
Novarossi 9901/41019
if the 41019 is not suited, which manifold should I get?
)EIB( is offline
