Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-09-2015 | 05:52 PM
  #7531
Ray does great work. You won't regret it
Chris Reilly is offline
Old 03-10-2015 | 06:26 AM
  #7532
sn47som1's Avatar
Hey guys hope all is well. When getting a brand new engine from the factory, is the idle gap set correctly? or should I pull the restrictor out and set it to .5-.7mm with a paper clip?
sn47som1 is offline
Old 03-10-2015 | 12:07 PM
  #7533
Guillermito's Avatar
Hello, I wonder if is any special screwdriver to screw the back cover? If I have the special Hudy screwdriver to the screw head ... but I do not want to damage the screws on the back cover.
Thank you very much. Best Regards.
Guillermito is offline
Old 03-10-2015 | 06:12 PM
  #7534
houston's Avatar
4mm flat
houston is offline
Old 03-11-2015 | 09:14 PM
  #7535
What size is the rear bearing on a bonito ?
travertini is offline
Old 03-13-2015 | 06:34 AM
  #7536
sn47som1's Avatar
Hey guys what are your favorite plugs for the P5? What has been the worst and best plug in your experience?
sn47som1 is offline
Old 03-14-2015 | 05:12 PM
  #7537
houston's Avatar
Its 14.5x26x6mm
houston is offline
Old 03-15-2015 | 09:12 AM
  #7538
trax70 guy's Avatar
Default Bonita bearing
Mr houston
The 14.5x26x6mm
Is there anything special about that bearing And will it fit the keep off 7 as well??
thanks
john b
trax70 guy is offline
Old 03-15-2015 | 11:28 AM
  #7539
houston's Avatar
Originally Posted by trax70 guy
Mr houston
The 14.5x26x6mm
thanks
john b
keep off and newer are same size but inner race is recessed on the back which requires a special bearing
houston is offline
Old 03-16-2015 | 07:56 AM
  #7540
houston what you think about putting an 28-7clock motor in a Gt serpent? or should I put that is a buggy? if so i like your opinion and if not the 28-7 in the serpent what other motor. only going to be doing speed runs and drag racing. not buggy though just grass bashing road maybe a little dirt at the track with the guys at events competing.
lighttravler is offline
Old 03-17-2015 | 10:50 PM
  #7541
houston's Avatar
If youre just playing it doesnt really matter does it?
Put it in wtvr car you like and have some fun
houston is offline
Old 03-19-2015 | 04:30 AM
  #7542
zachattak's Avatar
So hey, Ive come to think that long manifolds give more low end torque, and short manifolds assist in high end rpm?
zachattak is offline
Old 03-19-2015 | 07:12 AM
  #7543
cczjordan's Avatar
Yes. It do
cczjordan is offline
Old 03-20-2015 | 01:50 AM
  #7544
cczjordan's Avatar
Regarding rex paloma blue head with 9901/021 combo in buggy, what is an AVERAGE run time/tank.
Another question is will 9886/021, 2096/021 smooth out d bottom n give better run time.
Thinking of rex paloma or rex legend 4.
Old 03-20-2015 | 02:35 PM
  #7545
I have a Paloma all I can say so far so good . Was real easy to break in, idle all day if you let it . Only have tried one pipe and that was a werks 2058 man she is fast . Easy to tune and I am not no tuning expert at all . I started with the 6.5 Venturi and was getting 9mins to a tank of gas . Changed Venturi to 5.4 but motor was not working to good . Probably could have tuned it to be better but I just put the 6 Venturi in and bang she was working as per normal . With that last Venturi change motor temps at 245 degrees and last 11mins to a tank of gas . All I can say so far has way more bottom end then my plus 4 I had , let see if it last as long .
Eastside777 is offline
