NOVAROSSI Engine thread....
#7561
#7563
You can, if you're really, really super careful about tightening the plug..
I used to run them all the time because I felt like the engine ran better with them. But if you're in a hurry, or for example your pit guy discovering a dud plug just before a heat starts, you risk the dreaded gorillatighten deformation..
The taper has the same angle and everything, it's just the tapered area is smaller on the OS plug, so it's pushing on a smaller area of the head button. Hence if you slightly overtighten it, you deform the head button.
So.. if you are 100% sure you will always be super super careful with tightening it.. sure.. but if you think maybe one day you'll be in a hurry or your pit guy will replace a plug.. better run a Nova plug. Hence.. I'll just be running the Nova plugs from now on, even if they cost more and need more frequent replacement.
#7564
#7567
Hi everyone I'm looking to get a new engine for my truggy and I've been looking at the p5 Clio with a 9901 pipe an from what I've heard it's just like the old p5 but I thought I'd ask if the Clio was ok in a truggy.
Cheers
Ross
Cheers
Ross
#7569
Hey Monty,
I got a Nova keep Off 4-port which was pre-run from the factory. I've run a little less than a quart through it so far (at 200-215*F) to help seat everything further. The engine has about 5 tanks on it so far. How much more fuel do you think it needs before i can put a slightly rich race tune on it?
Tom
Tom
#7570
Hey Monty,
Tom
Tom
Idle 1 tank or 10 min of fuel with the fuel you will be using , after that tune about 75% performance for a few (3-4) tanks on the track then race tune . Ive seen people (pro drivers who are friends) do too much break in after nova pre run and lost compression almost instantly ,ooops , ive explained to them this method and why ,now they are going through wayyy less engines
#7571
#7572
Novarossi factory pre run?
#7573
from my experience the 9901 calm down the p5 and it ran a lot smother I installed the 2096 and it felt like it had more torque at bottom end and mid.i know u said u have the Clio and it's not much different from the p5 .imo it's just like the maxy cinco .
#7574
Ok well I have a 2096 in my buggy at the minute so I might buy the Clio and try the 2096 on it,thanks for the help
#7575
1. Get a proper idle gap, then either richen/leaning lsn to get it sound good
2. Put on track n make wot run, tune for hsn
3. Finalize with lsn as the hsn with effect a bit on lsn
352Likes
