Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-10-2016 | 09:21 AM
  #8746
am
exhaustvalves would be so awsome in theese engines
am is offline
Old 02-10-2016 | 10:03 AM
  #8747
Suspended
So would a reed valve. It'd be super interesting to see what the result would be.
Socket is offline
Old 02-10-2016 | 10:06 AM
  #8748
yes a kind off exhaust valve ,,,a spring valve clape system can really makes the diference ,we were testing an inox pipe originally made for rc nitro boat which has a spring valve custom system ...so i mean by this way you can have a 3 chamber pipe at low rpms and at the same time a 2 chamber when it revs
nick m is offline
Old 02-10-2016 | 11:10 AM
  #8749
Quite poor is my guess, a rotary valve is by far better. Getting reed valves to work at the rpm these engines run would be next to impossible, and nothing would be gained.
NitroVein is offline
Old 02-10-2016 | 11:55 AM
  #8750
Roelof's Avatar
To be honest... Yes, there are tracks under fire of strong envirement laws needing to make low noise or even no noise (only electrics) but I do believe that amount is very low. I also know tracks were forced to quit due other projects on that ground which wrongly used as an example what can happen when making too much noise.
The EFRA is such an organisation I think responsable for too much noise. If they really had accapted onlty the pipes comply to their noise limit we would have low noise pipes for years but sadly the homologation fee is more importand than the noise level.
Now the EFRA is working on a noise measurement and changed the naming "homologation" into "registration", so the responsabillity becomes with the driver to comply with the noise limits. I think that is also why an ENS is attracting more drivers than an European championship because the ENS is not hanging onto noise levels.
Roelof is offline
Old 02-10-2016 | 01:32 PM
  #8751
Suspended
What pipe is this that Jerome Sartel is running?
Socket is offline
Old 02-10-2016 | 01:40 PM
  #8752
kgombe's Avatar
Rules are rules.... if you don't like the rules go play elsewhere... :-)
kgombe is offline
Old 02-10-2016 | 11:11 PM
  #8753
Looks like a 2041. Kinda' hard to tell, but if the stinger is perpendicular it's a 2041 Turbo. 2041's are very popular in Europe. One of the best all-round pipes ever IMO. I sold both mine, unfortunately...
Hard to tell exactly from that angle, but it could be a different Mielke pipe. Mielke-made though for sure..
Herrsavage is offline
Old 02-11-2016 | 07:09 PM
  #8754
Default 41019 vs 41032
Is the mileage better with the 41019 header vs the 41032? If so, about how much better? I'm assuming the 41032 is more powerful being that it is conical.
What is this I hear about the double bend headers can seem to lean bog at low rpm?
qstorm777 is offline
Old 02-11-2016 | 10:01 PM
  #8755
both of them are for top end and open tracks .i wouldnt use 41032 for off road ,,,,untill now i use it for gt cars ,,,i have seen better results with 41001 and 41005 at buggy and trugy ,,41031 and 41021 are also good choices ,,,you have to make a test in a middle track with all to find your favorite
nick m is offline
Old 02-18-2016 | 10:51 PM
  #8756
Looking to run nitro this summer and I'm wondering about some motors for my buggy. I used a 4btt a few years back and loved it. I'm curious whats the differences between the 4btt, mito and the virtus?
I run on a medium sized track so Im just looking for the best runtime possible.
nrm1977 is offline
Old 02-19-2016 | 11:24 AM
  #8757
HaulinBass's Avatar
i just picked up a nova nv21b, seems to share some internals with the bf but has a 15055 crank wich i cant find any info on. i dont expect much for what i paid but has anyone else run one, the box says square stroke i thought tbe 3 ports were all stroked like the p5s.
oh well $100 with a crappy tuned pipe cant really complain.
EDIT Pulled backplate and the crank is extemely simple and has a pullstart pin attached. will the 15007t crank fit?
HaulinBass is offline
Old 02-19-2016 | 02:58 PM
  #8758
fizzy's Avatar
Can anyone answer this with any detail, it seems difficult to get any info on the virtus and Mito line of offroad engines for some reason
fizzy is offline
Old 02-19-2016 | 03:23 PM
  #8759
vr6cj's Avatar
Not really. They're all here. http://www.novarossi.it/2012/index.php
Peer down into the engine page itself and it'll give detail and specs
and great place to buy is: http://novarossidirect.com/
vr6cj is offline
Old 02-19-2016 | 05:52 PM
  #8760
Default Specs
So can someone explain specs in general? I can't tell from specs if a motor is supposed to be a torque motor, speed motor or good all around, etc.
