Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-01-2014 | 05:31 PM
  #7081
zachattak's Avatar
Hi all! Jumping ship next year from REDS to Nova. First engines i got advised to try were the virtus in truck and +4btt wc in the buggy. Ive got a few ordered, all factory tuned and sealed. Any advice on pipes and header combos? I understand im probably the 100000th person to ask something like this, sorry!
Any help or pointers would be greatly appreciated
zachattak is offline
Old 09-02-2014 | 02:05 AM
  #7082
WildManDriving's Avatar
The Virtus I haven't run so can only guess 2096 or 9901 on the 41021. For the BTT WC I most liked 2096/41001 this fitted in the MBX7 geared 13/44T.
M.Ellis
WildManDriving is offline
Old 09-02-2014 | 05:50 AM
  #7083
buchanan88's Avatar
With the virtus, go with the 9853 gives you good bottom end response since the virtus already has a lot of top. 9901 will work well with the 4btt with the 41021 header.
buchanan88 is offline
Old 09-02-2014 | 10:32 AM
  #7084
sn47som1's Avatar
Hey guys, honored to be on this thread what an awesome resource! I need some expert or advanced advice which I know you guys can provide on a good carb needle setting for a great track tune, not necessarily a perfected RACE tune but something pretty close. I run a Novarossi Keep Off 7 with the newer carb (not the offset Virtus one but the newer gen carbs if you will) Im mainly looking for low and high speed needle settings, I can adjust the idol accordingly. Even good settings from a Bonito or other 7 port Novas or maybe even a P5 if same carb would do the trick? Thanks guys and Ill report back once on the track
sn47som1 is offline
Old 09-02-2014 | 04:17 PM
  #7085
Either the 9901/41021 or the 2096/41021. 2096 has slightly less bottom and more top end.
Chris Reilly is offline
Old 09-02-2014 | 05:54 PM
  #7086
Running the Plus 4BTTS with 41001/9886. Gobs of bottom end.
RiPPeN302 is offline
Old 09-02-2014 | 08:03 PM
  #7087
sn47som1's Avatar
sn47som1 is offline
Old 09-03-2014 | 06:46 AM
  #7088
I'm not sure you will be provided the answer your looking for - if you re-phrased the question to 'where are you needles after tuning' you'd get a better idea.
I've just run in my P5 and given it a safe tune:
7mm Venturi
HSN +3 hrs from flush
LSN +4 hrs from flush
That's running at circa 100/230 degrees with Byron 25-% with the ambient temp 20/70 degrees.
Prospec is offline
Old 09-03-2014 | 11:24 AM
  #7089
cczjordan's Avatar
Even same engine same carb, it always a tolerance. Some other factor is fuel n plug so i guess s long s a trail of smoke n good power will do. Sorry no answer for ur question
cczjordan is offline
Old 09-03-2014 | 11:59 AM
  #7090
Yep we get that, so is your HSN approx 2.9 or 3.1 fractions turned in from factory when set
Prospec is offline
Old 09-03-2014 | 03:28 PM
  #7091
SEF's Avatar
SEF
Maybe this will help with a basic setting. Starting at 3:25.
+ YouTube Video
SEF is offline
Old 09-05-2014 | 05:17 AM
  #7092
sn47som1's Avatar
7mm Venturi
I take it you mean 3 leaned in from flush and 4 leaned in from flush?
sn47som1 is offline
Old 09-05-2014 | 01:09 PM
  #7093
sn47som1's Avatar
Hey guys maybe not the BEST thread for this question? but has anyone experimented with different headers on the Werks 2013 pipe? like nova headers 41021 41001 with this type of combo on a nova engine for example? Or is the Werks one the best to run?
sn47som1 is offline
Old 09-07-2014 | 05:44 PM
  #7094
pword's Avatar
looking to try keep off 4 on my tki3. some are posting here that 2058 pipe works well with this engine. im currently running alpha dragon with ryan lutz pipe which i think is based on 2058. has anyone tried lutz pipe and keep off 4?
pword is offline
Old 09-07-2014 | 09:32 PM
  #7095
Camash's Avatar
Originally Posted by TerribleTy
Another thing to check is fuel flow. Take the tubing off of the pipe and carb then blow through the tubing from the pipe end. You should get a nice stream of fuel out from the carb line. If you don't its time to look at a new clunk filter. Sounds goofy I know but I've seen this many times.
Had a guy in the shop yesterday that had a nicely idling motor but as soon as we went to drive it lean bog like crazy. I went out to help him tune it up and after going rich over 1 turn on both needles I checked the clunk filter the way mentioned above a it barely dripped. Changed the clunk (coper looking filter in the bottom of the tank) and the engine ran perfect after a lot of leaning out.
There is no such thing as a Novarossi dud we will get it figured out.
Just thought I'd touch on this again walllah after 3 dud turbo plugs she's running like a gem I advise anyone with similar problems to make sure that your glow plug is in good working order cheers.
Camash is offline
