NOVAROSSI Engine thread....
#7051
yes they are in essence the same carb , they perform the same , tune the same so far as i have ever tested , there is like a .25mm difference in the underside/exiting bore which is not noticeable in tuneability or performance
yes the older R4 rod is the same dimensions as the newer R7 that is labeled in many dfrnt numbered versions
please stop the insanity ,lol
#7053
Tuning query:
I was running in my P5 last night, Byron 20% / 9901 pipe / 6mm Venturi.
Run in/progress so far:
first tank ran up to temp 3 times
3 further tanks - figure of 8's 1/4-1/2 throttle cooling between
3 further tanks - rich, running a circuit with full gas
Q. I've gone through quarter of a gallon, at idle slightly high tickover which slightly drops, after 10 seconds punches of the line clean plenty of smoke, maybe a slight hesitation/bog... Flat out sounds good, reving high slight trail of smoke - all seems good but the engine temps are way down 65c/165f which leads me to believe something's way out with the tuning?
#7054
Tuning query:
lean lsn and hsn
#7055
#7056
#7061
Tuning query:
Fook - had a look at it tonight, LSN was <5 turns out and the top was in from flush.. So the old newbie, too lean on top fat on the bottom mistake. The clue came from Cody kings tuning vid where he talks of the revs not laying down.
Hopefully the bottom being so rich compensated for the top and not done too much damage(there was still a trail of smoke on top.
Reset to factory and will take it to the track tomorrow and keep the needle increments steady.
Venturi was 6.5 up'd to 7.
#7063
352Likes
