NOVAROSSI Engine thread....
#7021
Seems oddly over-dramatic. I don't see why a simply differently branded plug would have the possibility to destroy a differently branded engine. They're both turbo plug engines, what else can be different? I can understand why you might not get the most out of your engine with a differently branded plug, but to destroy it seems over the top...
The noise has stopped, still not 100% sure of what it was as the top of the piston had no evidence of 'Knocking'.
#7022
The OS plugs have a different taper at the end. THey don't seal tightly in a Nova head button. If you crank on the plug when you install it the head button will distort the head button and Nova plugs (or any other manufacture) will not seal properly. SO no it will not destroy the engine, but it can distroy the head button.
#7023
Thanks for the Helpful info will keep a close eye on the seal between the Button head and plug.
Can anyone please confirm that the arrows on the bottom of the cooling fins and button head face forwards or backwards.
And if they were facing the incorrect way could it have been causing that mysterious 'Knocking sound' i was hearing before.
Thanks.
Thanks.
#7027
This has been a long standing debate...
If you tighten the plug up only just perfect, no problems!
The reason I prefer the OS P4 plug rather than the C6tgc nova, is that the OS plug is more consistent. Higher consistency between plugs.
By that I mean you run nova plug, change to new plug, and the tune is wildly different as a result, it's as if the nova plugs have a great variation between one plug and the next.
The OS plugs at least seem much more consistent, and more the same.
Also I find it a lot easier to tune, I am assuming the P4 might be slightly warmer than the C6, so that might be why.
If you want to run an OS plug in your nova, you should run the P4, at least that's what I like best, I think the P3 is too warm.
#7028
#7029
#7030
I just noticed this comment and just wanted to say:
Please stop posting misinformation like this.
This discussion has been done to death. Persons seeking to end this string of misinformation actually measured and posted photographic evidence that:
-The angle of the taper is 100% identical
-The length of taper is smaller on OS and bigger on Nova plug
-Therefore the actual taper is the same
-However due to the lesser area available for seal to occur in head button, you must be careful not to overtighten it, since there is a smaller section of taper pushing on the head button material.
So, in conclusion:
PLEASE STOP SPOUTING THIS RUBBISH THAT THE TAPER IS DIFFERENT. The angle of the taper, meaning "THE TAPER", is _THE SAME_, so please stop it with this regurgitation of misinformation.
Hence there is NO REASON, ZERO REASON, why you would destroy the sealing ability of the headbutton as long as you do not severely overtighten.
AS such, I have no problem running OS plugs in my Novas, and everyone else I know do the same.
Thank you.
So, in conclusion:
Thank you.
#7032
So, in conclusion:
Thank you.
So, in conclusion:
Thank you.
The length of the taper being shorter on the O.S. plug does not mean that the taper is different. It just means that the O.S. plugs are shorter than the Nova plugs, which, in turn, means that when you tighten the plug in the head button, the coil will just sit slightly higher than the coil of a Nova plug.
#7033
Does that mean you will replace every head button that gets damaged from your answer ?
At least some are trying to warn people of possible problems.
I would never put a OS plug in my Nova Rossi engine because of the reason mentioned amongst a few others.
#7034
So, in conclusion:
Thank you.
So, in conclusion:
Thank you.
For what it's worth I'll just keep on running my Nova engines with my Nova plugs tank after tank after tank...do you know why? I'll tell you why, my engines DON"T FLAME OUT! 4 years, 2 engines, only running Nova plugs (mostly C6 plugs), never a flame out and I don't run a safe, fat, gargling tune. But to each his own.
back to our regular scheduled program.
#7035
Thank you keyboard cowboy...I'm sorry about the misinformation I was spreading, thanks for clearing up all the bad info I have been spouting off.
I in no way meant to start a flame war on thsi thread but it seems the argument was left up to interpretation rather than making the details clear. Carry on
352Likes
