Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-24-2015 | 06:40 PM
  #7771
jonw's Avatar
Amen Brutha
Originally Posted by houston
Fyi , i have NEVER once been underpowered using 2096 41021 setup ,EVER and no im not a slow guy , i dont "bash" my cars in a field , I RACE RC CARS
I have had issues with bearings in chassis that made it feel like the engine sucked ,put 4 or 5 engines in and they all did the same thing , replaced all bearings and voila , issue solved , felt free with no load buuuut .......
Viva la novarossi
jonw is offline
Old 05-25-2015 | 06:20 AM
  #7772
Stubbs's Avatar
Originally Posted by Maximo
the 41021 manifold hurts top end quite a bit compared to a 41001... so if you want to go faster get rid of the 41021.... Looking at losing roughly 5000 RPM of usable powerband going from the 41021 as compared to the 41001....
How does the 41001 compare to the 41020? Not on this specific engine, but just in general?
Stubbs is offline
Old 05-25-2015 | 11:58 AM
  #7773
shannow's Avatar
Today I tried the 2096 vs 9901 and I preferred the 9901 although I'll probably not buy it.
With the 2096 you sort of have a "lag" between the moment you pull the throttle and the engine reeving up. It's small but with the 9901 the engine feels way more connected to the car. It's instantaneous.
Funnily the 9901 was faster in the straight even against the 2096 + almost 1/2 leaner on the HSN. Weird as everybody agree on the oposite.
The 9901 is much louder.
Apart from that the lap time was pretty close and not worth me rushing to buy the 9901. Maybe when I'll have some spare money laying around...
Thanks again for all the help
shannow is offline
Old 05-25-2015 | 04:47 PM
  #7774
cczjordan's Avatar
Thats strange, which manifold?
cczjordan is offline
Old 05-25-2015 | 10:30 PM
  #7775
houston's Avatar
With a P5xlt ?
The bearings have all been changed with the P5xlt and are regularly checked one by one every two weeks or so during the full disassembly for cleaning purposes. So I think I'm clear for this problem (gear mech is ok too everywhere and I'm using the std spur with a 13t pinion) .
I just don't understand why my engine doesn't sort of leap forward like the other guys do .
The lsn has been set 1/4 turn rich when the engine started to be a bit lean. It was actually set 1/8 leaner than what I have by the local pros but I found was then a bit of a pig to start.
I'm going to strip the clutch to double check the spring thickness.
Thank you again for all the inputs !
Hsn too lean , lsn too rich ,,sounds like typical mistune on a novarossi
At least thats what it sounds like
If youre richening your lsn to get rid of a "lean bog" youre doing it wrong
houston is offline
Old 05-25-2015 | 10:33 PM
  #7776
houston's Avatar
Maybe your 2096 has an issue ,needs to be cleaned internally or broken internally? Something to that effect
houston is offline
Old 05-26-2015 | 09:14 AM
  #7777
That's odd, because "everyone" including myself like the 2096 way better.
9901 less topend, different bottom end.. I just don't like it much.
Eivind E is offline
Old 05-26-2015 | 10:32 AM
  #7778
shannow's Avatar
We tried on both my mate's BTT4 and my P5xlt with two separate 2096 so it's unlikely a faulty 2096 I think .
He retuned his BTT4 when he changed the can (going from 9901 to 2096) he had to lean quite a bit.
I didn't change much my tuning going from 2096 to the 9901 the top end was ok but it's true the LSN (?) was a tad too lean you could almost hear the engine bog but only at the end of the long straight when closing totally the throttle at full rpm. Wasn't sure to touch the lsn or hsn and as it was just a lend I didn't wan't to upset my original settings, maybe I should've been braver.
One thing I discovered yesterday is that I'm the only one with a 13t bell... everybody has a 14t on their car. It could help as the surface is very slippery (1/2" very thin dust on hard pack almost like flour).
shannow is offline
Old 05-26-2015 | 04:35 PM
  #7779
cczjordan's Avatar
Just richen hsn 1-2 hours will not harm d engine, but keep the idle gap n lsn correct
Old 05-27-2015 | 07:29 AM
  #7780
Maximo's Avatar
Default 41001 vs 41021
On this engine the 41021 did pretty good in comparison...you can see the 41021 has a slight advantage in the early midrange, but the 41001 has more initial power , broader powerband and more peak HP....
Maximo is offline
Old 05-27-2015 | 07:41 AM
  #7781
Maximo's Avatar
And here is another graph from the same engine comparing the 9901, 2096 and a RB 2097..
Maximo is offline
Old 05-27-2015 | 07:46 AM
  #7782
Maximo's Avatar
Maximo is offline
Old 05-27-2015 | 06:33 PM
  #7783
cczjordan's Avatar
Can someone pointed out which color belong to which pipe, good analysis but not so good labelling
Old 05-27-2015 | 06:44 PM
  #7784
kgombe's Avatar
royal blue and green 2097
light and red 9901
purple and yellow 2096
kgombe is offline
Old 05-27-2015 | 11:29 PM
  #7785
AllyITA's Avatar
that sudden drop at 32000rpm from the 9901 seems a little odd.. why is that?
AllyITA is offline
