Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-14-2016 | 08:53 PM
  #9271
Maximo's Avatar
Originally Posted by Audiobahnaholic
Can you remove the shim on all nova engines? I'm running a plus 4 btt and thought about doing this
More or less yes you can.... Novarossi are extremely conservative and leave plenty of room to to remove shims.... this is why a OS Speed seems soo powerful..OS doesn't mess about and runs their heads 0.2 mm closer to the piston then Novarossi does... which can add up to a huge power increase
Maximo is offline
Old 12-14-2016 | 11:19 PM
  #9272
HaulinBass's Avatar
does anyone know if nova built another square stroke motor with a 14mm crank other than the 3cq/nv21b?
HaulinBass is offline
Old 12-14-2016 | 11:49 PM
  #9273
Roelof's Avatar
Ielasi tuned and the older RB WS series
Roelof is offline
Old 12-15-2016 | 12:28 AM
  #9274
HaulinBass's Avatar
Like the ws7III? I thought those were 13mm cranks
Old 12-15-2016 | 02:01 AM
  #9275
Roelof's Avatar
Yes, you are right... 13mm... (not sure about the WS7-III)
Roelof is offline
Old 12-15-2016 | 08:21 AM
  #9276
I Guys, I just bought a brand new Nova VirTus 21/S Off with double ceramic bearings.
Which recommended muffler for medium-long circuits?
aulin79 is offline
Old 12-16-2016 | 05:59 AM
  #9277
cczjordan's Avatar
41021/2096, 41032/9886
cczjordan is offline
Old 12-16-2016 | 06:49 AM
  #9278
Picked up a Legend 7, 41031 manifold, and 51016 (9901) pipe. Anyone have experience with this engine? I'm putting it in a buggy.
GAPaman is offline
Old 12-16-2016 | 08:21 AM
  #9279
Default Thanks
What about a OS Speed 2060 or Alpha Plus 2107 ?
aulin79 is offline
Old 12-16-2016 | 09:13 PM
  #9280
cczjordan's Avatar
Legend 7 is very smooth, good combo with the pipe but i never like it, prefer 2096 n 9886 only for nova pipe line up
Old 12-19-2016 | 04:12 AM
  #9281
elex300's Avatar
Will this bearing work as a replacement for a Mito4 or is the Nova bearing the only option?
elex300 is offline
Old 12-19-2016 | 04:30 AM
  #9282
Roelof's Avatar
http://www.novarossi.it/2012/index.p...-off-road.html
Nope, no direct fit due the smaller inner ring. You are stuck with the most expensive bearing there is.....
I have modified a crankcase once to fit a normal bearing:
http://www.rctech.net/forum/onroad-n...gs-virtus.html
Roelof is offline
Old 12-19-2016 | 04:38 AM
  #9283
elex300's Avatar
Well that sucks,lol
Does the Hudy tool work to remove this bearing?
elex300 is offline
Old 12-19-2016 | 02:40 PM
  #9284
cczjordan's Avatar
Originally Posted by elex300
Well that sucks,lol
Yes, tko has the bearing, same as keep off bearing
Old 12-19-2016 | 03:27 PM
  #9285
HaulinBass's Avatar
The mito have a 14.5mm crank like the keep off 7 and virtus. Noone else makes that bearing cheapest I have found for a replacement ceramic for it is about 70us
