Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-16-2013 | 02:12 AM
  #5566
I used to run my P5 around 240-250 with no longevity problems. They really do run hotter than other motors, but they last just fine like that.
Matthew Bailey is offline
Old 05-16-2013 | 02:39 PM
  #5567
Ahh I was turning 1-2 or 3 hours at a time...Way too much I guess.
Thanks I did not know these carbs were so sensitive.
Originally Posted by chicky03
I could be off but I think you have your tuning lingo is wrong. One hour means 1/12th of a turn. Basically 5 minutes if you want to get techinical. One hour is not one full turn. You should be making adjustments 1/12th of a turn at a time. I usually do a blade with of the screwdriver at a time, if you are far off this will take for ever though. A p5 should run up to 260 with no real issues. I don't even use a temp gun anymore, I just lean it until it starts to make good power and don't go much further. The more you do it the more you'll get a feel for it. The engine should clear out nice and sing down the straight. If you like the way it runs at 240 you are well within the range of safe.
alex_blais is offline
Old 05-16-2013 | 03:30 PM
  #5568
you definitely can't turn one 3 hours. You will be out of wack quick
evolution03 is offline
Old 05-17-2013 | 04:26 AM
  #5569
t0p_sh0tta's Avatar
I'm around the 3/4 gallon mark on my beat B4 (based on the 21-4), and it runs about the same when I've temped it. If I go an hour richer it bogs like hell, so I can agree they run a bit warm, but it's a happy as a pig in its own muck.
t0p_sh0tta is offline
Old 05-17-2013 | 08:49 AM
  #5570
Default Backwoods engine fix
My P5 was toast after a re pinch it lasted 1 gallon the guy that did it did not polish the piston and sleeve so the scratches on the back side of the piston were still there only making the problem worse. So until I get a new motor I have taken the sleeve and wet sanded .003 off of the top of the sleeve then put it back together. Instant compression it runs now hopefully it will get me through the weekend that's all I'm asking of it. Then I will buy a new motor.
Sneakyweasl is offline
Old 05-17-2013 | 12:19 PM
  #5571
Guillermito's Avatar
Hello, someone tried the Keep Off 7 with 2096 pipe? Or is it better 9901 for this engine?
Thanks. Best Regards.
Guillermito is offline
Old 05-17-2013 | 01:30 PM
  #5572
THE PHILLY JYNX's Avatar
This should have been posted in the 818 Mods thread
THE PHILLY JYNX is offline
Old 05-17-2013 | 05:03 PM
  #5573
sschultz's Avatar
sschultz is offline
Old 05-18-2013 | 09:15 AM
  #5574
i tried my 4btt tuned with sworkz pipe combo and it really really out perform my 9901 pipe
yollie is offline
Old 05-19-2013 | 06:37 AM
  #5575
aussies1129's Avatar
Default Roma
Anyone running the Roma just want to get an
Idea what carb insert you find best and how close
To flush have you got both needles at?
Cheers
aussies1129 is offline
Old 05-19-2013 | 01:58 PM
  #5576
I'm using the 6.5mm venturi (blue color), and the two needles are nearly flat. But the needles also depends on the weather.
Best Regards.
Old 05-19-2013 | 03:55 PM
  #5577
Best Regards.
Thanks for that I just changed to the blue insert
My needles just above flush but wasn't getting the top end zip
I was looking for I mite try a hotter plug ?? Cheers
Old 05-20-2013 | 05:28 AM
  #5578
Which Sworkz pipe would that be, the one which is the same as the OS 2090SC?
Eivind E is offline
Old 05-20-2013 | 11:30 AM
  #5579
Is it normal that my P5 XLT needs a new rear bearing after 1.5 gallons or am I doing something wrong?
Old 05-20-2013 | 11:37 AM
  #5580
Maximo's Avatar
what fuel do you run ?
rear bearings can be damaged by poor quality fuel....rapid RPM spikes while engine is cold...improper breakin of the bearing.......Over revving the engine..... running too lean.......
Maximo is offline
