Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-07-2013 | 06:10 PM
  #5281
hookem34's Avatar
R/C Tech Elite Member
Originally Posted by RockStar_199
I have a btt that I need bearings changed. Local hobby shop didn't have the correct bearing puller. Does the hudy come with everything I need? I also need bearings for it....what are the sizes, I can't seem to find the correct ones.
Mark I have the Hudy tool. It works perfect on the Nova's. If you want to try it out, let me know.
hookem34 is offline
Old 04-07-2013 | 06:56 PM
  #5282
Have you changed a bearing for a btt? I just need to know if the hudy kit is able to do that motor because I think the btt have diff size bearings
RockStar_199 is offline
Old 04-07-2013 | 06:57 PM
  #5283
hookem34's Avatar
Yep, changed my CRE BTTS with no issue.
hookem34 is offline
Old 04-07-2013 | 07:05 PM
  #5284
Thanks that's all I needed to know I just bought one
Old 04-07-2013 | 07:26 PM
  #5285
hookem34's Avatar
Nice! The 17011 front bearing has a raised inner race, so make sure you place a washer between the bearing and bearing cup to prevent you from smashing the race. Sounds weird, but look at it when you get the tool and it will make sense.
hookem34 is offline
Old 04-07-2013 | 09:01 PM
  #5286
houston's Avatar
It takes a lil customzing or a machined washer that will only touch the outer race of the 17011 as it has an inner race that protrudes .3mm , seen allloooottt of messed up front 17011 because of this
houston is offline
Old 04-07-2013 | 09:32 PM
  #5287
I'm just going to send it to you lol
Old 04-07-2013 | 09:51 PM
  #5288
houston's Avatar
Thats no prob bro
Just lmk
houston is offline
Old 04-07-2013 | 09:56 PM
  #5289
RCNitro13's Avatar
With the button head, which way does the arrow point? I took it off but didn't pay attention to the orientation.
Also, should there be movement of the flywheel when the piston is right at the top of the sleeve? With the heat sink and back plate off, I noticed a few mm movement left and right when the piston was stuck at the top. The pin on the crank that goes into the bottom of the rod seemed a bit loose.
RCNitro13 is offline
Old 04-07-2013 | 10:05 PM
  #5290
houston's Avatar
Tdc is not where to check for rod/crankpin "slop" , thats normal
Towards exhaust but is a circle and will not hurt anything either way
houston is offline
Old 04-08-2013 | 12:17 AM
  #5291
RCNitro13's Avatar
[QUOTE=houston;12021255]Tdc is not where to check for rod/crankpin "slop" , thats normal
OK, thanks. How would you check the slop?
Old 04-08-2013 | 12:46 AM
  #5292
houston's Avatar
[QUOTE=RCNitro13;12021494]
usually at the start of the compression stroke or get all technical and measure crankpin , under 4.92mm bad
houston is offline
Old 04-09-2013 | 07:26 AM
  #5293
what is the best fuel to run in a .21-4C engine? I normally use Byron 30% in my current engine, but noticed novarossi recommends 25%. I was thinking of 25% worlds blend
R.M.S is offline
Old 04-10-2013 | 06:23 AM
  #5294
beidle99's Avatar
30% is fine. That all I run on my plus 4 btt. Can't go wrong with Byrons.
beidle99 is offline
Old 04-10-2013 | 09:50 AM
  #5295
Perfect, Thanks!
R.M.S is offline
