Like Tree352Likes
NOVAROSSI Engine thread....
Old 09-24-2012 | 12:29 PM
  #4051
kgombe's Avatar
Originally Posted by Sergey D
Thats happened, because you are use incorrect insert.
The internal channel inside of the new carb is 6.0....
And when you are install 6.5 isert, you make a "step" for flow....
Sorry for my english
the internal diameter is 7mm
kgombe is offline
Old 09-24-2012 | 04:29 PM
  #4052
run_pais's Avatar
if anyones interested in a never seen dirt novarossi bonito (rear ceramic bearing version) send me a pm.
I put 2 tanks on idle with the engine warmer on the engine to start the break in; still need to compete the break in.. $355 shipped
run_pais is offline
Old 09-24-2012 | 05:31 PM
  #4053
houston's Avatar
24065 is 7mm
2 turns out from bottomed out?
i ended up with my adjustments on the 24065 wayyyyyy too far in for my taste and i deduced that the carb was just not right , i switched back to 24069 or 24063 and it ran awesome again
i believe i ended up 1 3/4 turns out from bottomed out and it was still rich on the lsn uggggh
honestly in "racing applications" 99% of all nova users and allll of the "pro" level drivers use 41021 , coincidence ? i think not
houston is offline
Old 09-24-2012 | 07:11 PM
  #4054
Hi, I was wondering what's happening to my 21-5. It's near finished breaking in, at least it feels like it's fast, and not bogging down. Sadly it's VERY hot (250f) and if I try to richen it it bogs.
fung_kyle is offline
Old 09-24-2012 | 09:27 PM
  #4055
houston's Avatar
Its not horrible kyle
Try to keep temps under 240°ish until nuts drop though
The most common mistake made with the break in of nova engines is when users try to lean em down to make power before they're ready to be leaned out
houston is offline
Old 09-25-2012 | 04:58 AM
  #4056
Maximo's Avatar
Originally Posted by chopper82p
Neal says 41005 makes the engine feel lazy, 41001 would be the best, a lot better than the 41021.
On a Bonito it sure does........Probably explains why some here think the Bonito is lazy LOL..........On a BTT the 41001 makes more torque and RPM then the 41021 makes......Same for the P5......... Most do run the 41021 but that is likely because they have never taken the time to test anything else...........With us we blaze our own path, we don't just blindly run/recommend something because that is what everyone else is running........
Maximo is offline
Old 09-25-2012 | 05:06 AM
  #4057
Lille-bror's Avatar
Have you tried 41001 on a Plus4 Team?
Lille-bror is offline
Old 09-25-2012 | 05:16 AM
  #4058
Maximo's Avatar
YES !!! roughly 4 MPH more on our straight and noticeably more grunt off the bottom as opposed to the 41021.........Maybe it makes it too aggressive for some tracks ? However on our track surface the owners of the stock Plus4 are usually looking for more juice and the 41001 wakes it up nicely over the 41021...... Don't just take my word for it, just try it out and see for yourself what you think...The engine will even sound nastier and throatier on the 41001........
Maximo is offline
Old 09-25-2012 | 05:30 AM
  #4059
afr0sch's Avatar
If you can drive and maintain your momentum an engine with massive bottom end power is not required, on any track.
afr0sch is offline
Old 09-25-2012 | 05:49 AM
  #4060
kgombe's Avatar
Thank you...
kgombe is offline
Old 09-25-2012 | 06:08 AM
  #4061
Maximo's Avatar
Originally Posted by kgombe
Thank you...
Nice, but this isn't the debate here guys......
plain and simple if someone is using the 9901/41021 on their Plus4 and happen to be looking for more kick ( which some definitely are based on the posts here ), then they can find that extra kick by installing the 41001 manifold instead............ The 41001 will give a little crisper throttle down low and a substantially better mid range and top end run out..... If someone is happy with the output of the 41021/9901 on its own then they have no reason to change.......
Maximo is offline
Old 09-25-2012 | 06:25 AM
  #4062
afr0sch's Avatar
Yep..not rocket science. Newer racers sometimes feel that a faster engine will make them faster on the track. Not true unless you can handle the power and not overdrive.
If you are bashing, feel free to blow your tires off of the rim. We all have fun in different ways with these things. Just trying to give those that get what I am saying something to think about.
I always appreciate the data in this thread from those that have experience in the subject matter. Those that have actually tested their proposed engine/pipe/manifold combos with several different users provide invaluable valid input.
I always tell the new racers I help at the track that getting info is good, but you always have to take into consideration the validity of it based on the source. ;-)
afr0sch is offline
Old 09-25-2012 | 06:36 AM
  #4063
Maximo's Avatar
We are talking about a stock Plus4 here......its anything but a wild monster of a engine....many guys have this engine on the 41021/9901 and are looking for more kick....I just showed them a way to find more kick....
As for testing, few here would match the amount of testing we do, nor match the equipment and facility we have for testing....dyno,test track,radar gun, acoustic tachometer.....we test everything and assume nothing.........
Maximo is offline
  #4064
kgombe's Avatar
no rocket science here.. i have driven all proposed combinations... and always go back the 21/9901 on my plus .. because well.. it worked for me.. and i was never short of torque or top speed on the track...
kgombe is offline
Old 09-25-2012 | 06:54 AM
  #4065
afr0sch's Avatar
That is why I appreciate your effort and value your data.
afr0sch is offline
