Like Tree352Likes
NOVAROSSI Engine thread....
Old 10-04-2012 | 07:17 PM
  #4201
Dr. Evil's Avatar
Talking Roma
At close to $400, I would hope the Roma can refuel itself..
Dr. Evil is offline
Old 10-04-2012 | 07:48 PM
  #4202
megasaxon's Avatar
Originally Posted by houston
i love working with the p5 style engines , they run pretty dam good , need a few upgrades from box stock but still a great engine , they do have a better front bearing in them these days though
Ran a 20 main saturday with my P5 in an MBX6T, pitted at 9:55, ran til the 20min mark and had a half track left to go. Finished my lap and ran 3 more laps and it ran out just after the start finish line. Lap times about 27 seconds...so i got roughly 11.5 minutes on a tank with it and they are stump pullers in a truggy. This was with a 7mm venturi and a 2084/21 combo, Werks lightweight clutch with alum shoes and 2 .9s and 2 1.0 springs, 13T bell
megasaxon is offline
Old 10-04-2012 | 08:43 PM
  #4203
houston's Avatar
Great setup but change the pipe and you will be mo' happy
houston is offline
Old 10-04-2012 | 09:10 PM
  #4204
megasaxon's Avatar
2096? what will i notice by switching to it?
Old 10-04-2012 | 09:12 PM
  #4205
Better mileage is my guess.
Chris Reilly is offline
Old 10-05-2012 | 05:53 AM
  #4206
shimano's Avatar
Wat are the needle settings for the Roma guys ( I know there all different). I am only getting about 7.5 - 8 mins, running 2069/21, 6.5 venturi, standard losi clutch. 2 Ali 2 comp. I think I have about 5 or 6 litres through it now. Also running 48 - 15 gearing.
shimano is offline
Old 10-05-2012 | 07:33 AM
  #4207
svengali's Avatar
I've been running a "clocked" Roma for half the year (switching between the Roma and the Bonito) and have had no problem getting between 10-11 minutes runtime in the 8T 2.0
I'm using the Nova 9886 pipe and an M2Clutch system and #8 venturi. The gearing - 50T spur and 15T bell. The motor seems deceivingly slow cause it hits top speed so quickly but she's definately not lacking.
svengali is offline
Old 10-05-2012 | 12:38 PM
  #4208
Dr. Evil's Avatar
Talking Roma/Bonito
Besides displacement, what characteristic differences are there between the two engines?? In a truggy
fuel mileage,
torque monter (hard to control, violent)
Dr. Evil is offline
Old 10-05-2012 | 04:41 PM
  #4209
shimano's Avatar
Roma needle settings
shimano is offline
Old 10-05-2012 | 08:05 PM
  #4210
aznitronut's Avatar
Stock 3 1/2 top. 5 bottom
aznitronut is offline
Old 10-05-2012 | 08:08 PM
  #4211
aznitronut's Avatar
How big is the track you race on? 48-15 is a little odd, why did you go with that gearing?
Old 10-05-2012 | 08:46 PM
  #4212
shimano's Avatar
It tames the bottom end just nicely and has plenty of top end.
shimano is offline
Old 10-05-2012 | 08:52 PM
  #4213
shimano's Avatar
Do u know what altitude your at as these are miles away from my settings. I think I'm about 80 - 100 m above sea level
What size Venturi r u using
shimano is offline
Old 10-05-2012 | 08:57 PM
  #4214
Suspended
Do u know what latitude your at as these are miles away from my settings. I think I'm about 80 - 100 m above sea level
Those are the stock needle settings.
You can't use other people's needle setting, they have to be tuned to your specific area, humidity, temperature, glow plug, engine age & sleeve wear, and altitude.
Start at the stock needle settings. Lean the bottom until you have a stable, consistent idle, where its doesn't two-stage (idle high, then start idling lower). Once thats done, drive the car and lean the HSN until you get a good top end, but keep it 1/12 turn rich on the HSN just to stay safe.
rcuser567345 is offline
Old 10-05-2012 | 09:18 PM
  #4215
aznitronut's Avatar
Where do you live?
