Like Tree352Likes
NOVAROSSI Engine thread....
Old 11-07-2011 | 01:28 PM
  #1741
Chris Peralta's Avatar
If someone tells you there is only one right way to tune an engine they probably only know one way. If you know what your doing you can make an engine run fine no matter how you go about tuning it. Whatever works best for you is all that matters really!!
Chris Peralta is offline
Old 11-08-2011 | 05:32 AM
  #1742
aussies1129's Avatar
Originally Posted by 071crazy
I believe that the bottom needle should be tuned first. That way, your top needle tuning becomes pretty straightforward, along with your idle. It's way more difficult attempting to tune the top needle first.
I only do this when running in an engine, but once its ready to go the hsn needle is the one I look to first only reason is when adjusting the hsn it will also effect the lsn as well, adjust your hsn to get your engine revving hi to get top speed with a nice smoke trail then go back to the lsn for ballistic take off, if you do it the other way you may experience your engine running lean on the low side. once you have both of the needles tuned enjoy
aussies1129 is offline
Old 11-08-2011 | 08:01 AM
  #1743
houston's Avatar
Set hsn fairly rich , controlling rpm's , tune lsn for a consistent idle , adjust idle accordingly then dial in hsn on the track
houston is offline
Old 11-09-2011 | 05:49 AM
  #1744
ABN Hoosier's Avatar
^^^ LIKE
I am trying to break in a Bonito and BTT, using a CompHeat Duece makes tuning more consistent. I hope it pays off on these puppies. Monty, I'm about one gallon of Sidewinder Stryke fuel in on the Bonito, do you think it is ok to use the S&W fuel now? I have 3 gallons just sittin there....I was told during "break-in" not to use it. My Bonito still has a lot of pinch. I was thinking maybe another half gallon of the Stryke maybe.??? LMK
ABN Hoosier is offline
Old 11-09-2011 | 07:42 AM
  #1745
well.......I was told by about two dozen people I would be fine using the Stryke fuel for break in...
Just wondering what the optimal point would be to run this S&W fuel.
Old 11-09-2011 | 07:50 AM
  #1746
Originally Posted by Muggydude
I may not be right, but I don't think stryke is a good break in fuel either
You want a lot of good castor oil, 11%+, the synthetic fuels like stryke aren't the best.
Maybe I'm wrong though. I've always used byrons 30% with 11% oil for the first gallon.
If it is fully broken in then it's probably ok to run whatever fuel you want.
I broke every single one of my engines in on the purple Strike Team fuel. I even broke in quite a few engines for others locally with Strike Team this year. Haven't we talked about believing all the BS you read on this site little man? Maybe there is castor, maybe there isn't, I don't care because it works. Don't try to turn 40,000 RPM during breakin and you will be fine. Take it easy and limit the sustained high RPMs with any engine and any fuel.
Old 11-09-2011 | 08:51 AM
  #1747
kgombe's Avatar
no offense here but you also post on this site.. so you calling your advice BS? if so what makes it better BS?? I'm just saying
kgombe is offline
Old 11-09-2011 | 09:50 AM
  #1748
I know this kid personally. I do post on this site. Also a lot of poeple with 2,000 + posts that do not know what they are talking about post bad info on here all the time. I am not saying who does and does not know what they are talking about but he has been known to think someone had 1000+ posts they must know what they are talking about.
Would you rather trust someone on the web that you know nothing about or someone locally that does well that you can personally see and ask questions too?
Old 11-09-2011 | 09:55 AM
  #1749
kgombe's Avatar
you basically called everyone that post on tho site BS... your negative comments on the info the site is offering is not needed
if you know him personally call him up!!! what you think about doing that next time???
kgombe is offline
Old 11-09-2011 | 10:09 AM
  #1750
I think I am an adult and will do as I choose. Thanks for the suggestion tho
Old 11-09-2011 | 10:11 AM
  #1751
kgombe's Avatar
yea it seems that just a thought...
kgombe is offline
Old 11-09-2011 | 01:56 PM
  #1752
This is getting blown way out of proportion.
Got my popcorn and drink. Get-R-Done!
Nova Rossi makes awesome engines.
Chris Reilly is offline
Old 11-09-2011 | 04:23 PM
  #1753
chhhhhhhh....
Monty, ya there, come in.....OVER...
chhhhhhhh....
Old 11-09-2011 | 05:01 PM
  #1754
Lets go back over that post, shall we? You need to read what I'm saying first Peralta, before you can start going off about I don't know what I'm talking about.
There is a reason why I said I THINK there peralta, I didn't say IT IS better or worse.
And just because it works doesn't mean it's better.
I like the bryons better in general anyways, in both the stock and mod engine.
So I should not defend the fuel I run when someone like you who "doesn't really know" says something negative like that? Heck you a MOD here, how do you know some new person doesn't get scared away from the product over your post??
Old 11-09-2011 | 05:44 PM
  #1755
houston's Avatar
boys good stuff
i have been able to take a number of engines apart that have been running team stryke( amongst other fuel brands ) and i will say without a doubt that it is not an "optimal" break in fuel as it has VERY LITTLE castor oil but on the same token odonnell which doesnt have much castor either doesnt seem to coat the piston/sleeve fit (compression seal) area as much as team stryke does . i have noticed that the team stryke leaves a build up on the piston and the sleeve where they meet to form a compression seal and unless running the engine above 230° range the "proprietary lubrication" oils sidewinder uses will for lack of a better term shellac on the surfaces of the piston/sleeve. i have also noticed a buildup of what looks like melted crayon on the intake throat of the crank weird
take it how you wish but castor is IMO a necessity when breaking in engines , i would recommend at lest a 6% castor blend , byrons race 3000 = 6% castor 5% synthetic blends , i am happy using this fuel for at least break in , not a bad idea to run all the time
i have tested some blue vp powermaster fuel and i can tell ya it is a great fuel also ( dont ask )
houston is offline
