Houstons Engine Service H.E.S.
#6991
#6992
both good pipes though
#6993
Hi. Monty. Thanks for the Monty touch on my P5XLT. I've decided to break it in next season seeing my outdoor race season is going to be cut short.
My question is this. IF I don't use Nova Rossi glow plugs in this engine, did I hear a rumor that there is a glow plug that can mess up the head button on the Nova Rossi engine. Something about once you use these plugs, you should never insert any thing but them and you can't go back to the Nova Rossi plugs.
#6994
Tip: use a c5tgc or odo 97t for break in , it will help immensely
Hope this helps
#6997
#6999
Its not a rumor , its true that the shorter taper on the seal area of OS style plugs will deform the head button on a novarossi , sometimes (more often then not) if you try to switch back to a long taper seal (novarossi) style plug then it will not seal properly and performance/reliability suffers dramatically
Hope this helps
Hope this helps
#7000
#7002
#7003
#7005
22Likes
