Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 02-29-2012 | 09:29 PM
  #6241
BLKNOTCH's Avatar
Originally Posted by haagy3000
hi guys i got a novarossi 21p5xlt from H.E.S it has been running great up until last week when i was at my club race day the first 2 rounds it went fine but after that i had trouble every time i gave it WOT and let it come back to idle it dies the engine has had about 7 litres i have tryed plugs and looked for air leaks the plugs i have tryed are novarossi C5 & C6 and O'donnell 97t & 99t.
Any help would be muchly appreciated.
Haagy
What you may have is a leaking front bearing, I had this issue 2 seasons ago and that was my issue. To confirm get the engine running then spray brake cleaner in the area of the front bearing, if the engine dies when doing this then replace the front bearing if nothing happens then feel free to spray other areas to conferm and also look at the clutch condition.
Sean
BLKNOTCH is offline
Old 02-29-2012 | 09:53 PM
  #6242
Seattlelife22's Avatar
Haagy
When I bought my p5 from Monty he stressed to me to have him change the front bearing to the 17011 which I had him do...He said the stock bearing in the p5 is crap and will leak after about a gallon...Did you by chance have him do that if not i would say that is your problem..I am no expert by any means.
Seattlelife22 is offline
Old 02-29-2012 | 09:59 PM
  #6243
houston's Avatar
Originally Posted by motoazure
Monty,
What engine for the NCT tour 1/8 Buggy? I was thinking the Plus 21-4btt. What pipe with that?
Plus4 or x3
houston is offline
  #6244
houston's Avatar
Haagy
Specifics haagy
houston is offline
Old 02-29-2012 | 10:19 PM
  #6245
KWT-NITRO's Avatar
hey Bro,
H.E.S still rocking in Kuwait
http://www.neobuggy.net/modules/news...ywords=bullail
cheers Bro
Ali
P.S. ill try my best to give you double titles this year
KWT-NITRO is offline
Old 02-29-2012 | 10:24 PM
  #6246
Originally Posted by houston
Plus4 or x3
Can you message me with a setup I can buy? Engine and Pipe.
motoazure is offline
Old 03-01-2012 | 04:05 AM
  #6247
i have put a new ceramic bearing in and that one is only 8 tanks old
Specifics haagy
what specifics would you like houston
haagy3000 is offline
Old 03-01-2012 | 08:34 AM
  #6248
beidle99's Avatar
Monty,
do you have step by step break-in instructions for after a customer gets your bench break in service? How's my btta doing?
Nick
by the way...RC CARS ARE COOL!
beidle99 is offline
Old 03-01-2012 | 10:01 AM
  #6249
Originally Posted by beidle99
Monty,
Nick
+1
mikal is offline
Old 03-01-2012 | 10:29 AM
  #6250
porkchop's Avatar
Monty,
Nick
he sends a lil note with the motors he will let you know what eles it need
porkchop is offline
Old 03-02-2012 | 08:11 AM
  #6251
Trevor Williams's Avatar
R/C Tech Elite Member
yo!
call me when you got a sec.....thanks!
TW
Trevor Williams is offline
Old 03-02-2012 | 09:41 AM
  #6252
houston's Avatar
Stock, tuned, fuel ,pipe,plug,clutch, car , all that jazz
Call ya in a bit TW
houston is offline
Old 03-02-2012 | 11:35 AM
  #6253
sounds good....thanks Monty
Old 03-02-2012 | 02:51 PM
  #6254
the engine has been tuned fuel is 25% A.T racing platinum pipe is an alpha efra 2081 the plugs i have uesed are novarossi C5 & C6 and O'donnell 97t & 99t the clutch is a hot bodies clutch and the car is a hot bodies D8T
Old 03-02-2012 | 03:05 PM
  #6255
houston's Avatar
Haagy
R u sure its the engine and not something like the tank ?
Try a different engine of the same brand preferably and see if the same symptoms persist
houston is offline
