Houstons Engine Service H.E.S.
#6391
so I'm going to do something in Canadian indoor championship next weekend.. providing i have time to do the swap... I'm going to run the same engine in both classes... the question for you is what pipe do you recommend i use for both.. i want to use same pipe so i don't have to re-tune...
2096
9901
2084
these are the pipes i have
2096
9901
2084
x7 i would go with 2096ss for dual purpose
#6393
Im not a HES customer yet though I am good friends with a few of them. The advise and suggestions you give in all the forums are spot on. I myself have used your advise for different situations and it is much appreciated! Keep up the good work Monty!
#6394
I would like to thank Monty again for his amazing service! Once I placed my order he confirmed with me over the phone. Outstanding! He really goes all the way with customer satisfaction!
Monty- Since this is my first Novarossi engine. Any pointers so to speak? I use 30% byron's and always preheat my engines. So, I've got those covered. I was wondering for the rest of the break in process if I should just run it rich and start tuning to temp? Since I had you do the initial break in. Which I'm sure you did heat cycles. LMK what you recommend. Thanks again for your awesome service and expertise!
Nick
Nick
#6395
Nick
Nick
And with nova engines you actually have to tune the lsn
You'll get it bro
lmk if have any questions
#6396
Sounds good bro! I recall you saying the Nova engines tune a bit different then O.S. I know this is a generic question but, how so? I've always heard O.S. tunes very easy and is much more "user" friendly for someone whom isn't a expert. Thanks again for your time.
Nick
Nick
#6397
Os engines you can just lean the hsn and call it good , nova dont work like that , at least to get good reliable performance , watch the bernard durand video in "the tuning bible"
#6400
#6401
Well you know
...enough to get over any jump but not to where you cant control it under power...im planning on getting a JQ THE Car. Im not sure if the x7 fm is too much or even if the x3 fm is too much or not enough.
#6402
#6403
#6404
22Likes
