Houstons Engine Service H.E.S.
#6706
Would you reccomend the plus4 team c motor or the 4btt in an xb9? I would prefer more bottom end than my os v spec with the same top end or more would be ok. More than anything I want a super crisp and smooth motor. Also what pipe would you reccomend for the nova motors?
#6707
i also offer a fusion X3 lightning worth looking at
all three great engines
check stuff out at HES link below
#6708
4-c team today and was pleased with it, but it seems to be lacking in top end compared to my v spec. Keep in mind my v spec had just over three gallons on it and his had roughly one.
#6709
Get the bench break in, worth every penny.
#6710
Thanks Monty. went to clean up my 9901 and noticed a couple of small dents in the bottom and might switch to my 2058 for this weekend if I can't get them pop out. The dents arn't bad and I am giving it the Anti-freeze bath right now to clean up the inside. try it out and see if it works.
Thanks...
#6711
#6712
Thanks again
#6713
You get a crockpot fill it with antifreeze and cook on high for about 12-24 hours depending on how dirty the pipe is. When you pull it out run some water and nitro cleaner through it, wipe down the outside and go to the auto parts store and get some aluminum polish and polish it up and it will be darn near close to new again. If you have a dremmel tool with a buffing attachment use it and you will get a better shine.
#6714
I really don't care about how the outside looks all that much but I still polish it. Cleaning the inside is what counts, it will bring a pipe back to life. The oils in our fuel will eventually build up around the baffle and start to clog the holes. Cleaning the pipe will bring it back to life and it won't feel "soft" any more. The build up happens over such a long amount of time the performance loss isn't really noticed unless you run a freshly cleaned or new pipe back to back with your old crusty one.
as for freezing, I put a small screw in the pressure line and put a piece of fuel tubing over it so it doesn't leak. The outlet can me covered or pluged with a stopper, and I use seran wrap or press and seal with a rubber band around the header connection point. That way when the water freezes and expands it will pop the dents out and then push through the seran wrap at the end instead of blowing out the seam at the chamber.
#6717
Monty,
I put a zip tie on the carb side of the slide boot and ran 3 tanks back to back to back without a problem. So either I had a very small leak that showed up on Saturday and a zip tie fixed it (doubtful, but strangers things have happened) but I also switched back to carbon shoes and the idle issue went away.
I was also running carbon shoes last week when the motor ran perfect. I'm not sure why running aluminum shoes would make for a crazy idle but it did. Anybody else ever have something similar happen? By the way the aluminum shoes were m2c's made for the AE flywheel. Time to order up some AE rtr carbon shoes.
#6718
I also think I'm having clutch issues. Last two races I had some kinda bog out of corners. Using all aluminum as well, with 1.0 springs. Think I'll try one carbon and all 1.1 and find out how long things last. LoL.
#6719
My idle issues were that it would high idle for some stops and idle regular for others even at 5 turns out from bottom on LSN. It was really weird, that why I was thinking an air leak and Monty suggested checking the boot and pinch bolt. Its all good for now...just need it to drop its nuts now
#6720
Comp Heater In Phoenix already scheduled for delivery tomorrow. Just in time for the race!!! Thanx again Monty for your services, and answering my texts. The industry is real fortunate to have guys like you around.
22Likes
