Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 09-12-2011 | 06:44 AM
  #5716
losi_racer's Avatar
Originally Posted by PERROTTO
Talked to a few people at the byrons race @ dirt burners about their bonitos and they told me that bottom end was non-existent until they filled the crank, so of course I took some time to watch em run and I gotta say it seemed to have low end grunt but top end was not what I was expecting. I could tell u that the bonitos LOOKED slow but that would be and unfair judgment as I have never tuned or driven one. But I can tell u that I have tuned a few Ninja engines and I am always impressed with the power they produce. My point really is that I don't THINK that u will get what u are hoping for out of the bonito based simply off of speculation
that why i am trying it out.
i wasnt trying to rag on any engine. I was simply stating what i seen compared to other engines. I do not have experience with either engine except for the little ive done breaking in the bonito
losi_racer is offline
Old 09-12-2011 | 08:10 AM
  #5717
PERROTTO's Avatar
Is ur bonito stock or has it been worked over at all?
PERROTTO is offline
Old 09-12-2011 | 08:42 AM
  #5718
losi_racer's Avatar
It's stock .
Old 09-12-2011 | 10:28 AM
  #5719
houston's Avatar
I will say the boneytoe has some legs
The 2096ss is awesome!
houston is offline
Old 09-12-2011 | 04:35 PM
  #5720
I would not say the bonito is slow by any means. I am currently running one and I have yet to be walked down or passed by another motor. I am running it with the 2096 pipe and I am just removed the copper shimm to make the overall stack .60 which I will be giving a test this weekend.
nick64merc is offline
Old 09-12-2011 | 04:44 PM
  #5721
Trugsta's Avatar
G'day Monty Im so sorry to have to re'ask this as I know you have answered this Question before Ive breezed through from page 80 to page 180 and couldnt find the answer..(I have pen and paper ready to write it down this time).lol.
OK. Im running the P5xlt with the 9901ss/41005 Headder I also have a GRP pipe and headder (cant remmber the numbers).
But you mentoned another pipe headder combo that would better suit my engine could you Please refresh my memory.?
money is not an issue as long as my engine/pipe combo is as gooder match as it can be...
Thanks in advance.
Trugsta is offline
Old 09-12-2011 | 04:58 PM
  #5722
merdith6's Avatar
Default Walking legs
Most 7 ports have legs and can walk all over and pull other engines on the strait away, but I've found that overall it depends on the track size and available traction...
On large open tracks the 7 ports will indeed walk all over and pull other engines, sometimes they even wave their arms as they go by.....
But the tracks large or small that have tight twisty turns and or jumps that are difficult to clear (jumps close to the turn) the more torque the better, and in my experience the 7 ports hit hard, but have a little more of a delay than the p5's and even plus 4's, even though the 7 ports can out jump them with more of a run at the jump...
I've never lost a race because my legs were not long enough, or my porting felt inferior to more manly engines...but i have passed guys on the inside because they overjumped the jumps and blew past the turns...
I had a 367, a toro, and still own an FMS and an x7 and they are the only two that seem to pull enough out of the turns, and the 36 and toro team only worked on the bigger tracks with smooth flowing turns...
I would like to see dyno results on the x7 versus the Bonito, just to clear up any misunderstanding of tourque production....and where in the power band they make torque
merdith6 is offline
Old 09-12-2011 | 08:01 PM
  #5723
houston's Avatar
Thanks in advance.
2096ss/41021 nuff said!
9901ss/41021 is what I prefer for buggy
houston is offline
Old 09-13-2011 | 10:56 PM
  #5724
KWT-NITRO's Avatar
hey Monty,
PM for you
KWT-NITRO is offline
Old 09-14-2011 | 12:48 PM
  #5725
Chad Millikan's Avatar
Monty I bought a P5XLT last June or so, and i went on Novarossi web site and there is new exploded view of the engine as of 5-16-2011. All of the part #'s are the same even the breakdown of the carb. But the carb as a whole is a new number. It went from 24069 (old) to 24063 (new). I thought I had the new carb already, whats the difference
Chad Millikan is offline
Old 09-14-2011 | 04:32 PM
  #5726
houston's Avatar
the difference in the carbs is the bodies , one has more metal and a 7.5mm opening in the bottom where the slide barrel hits and the other is all plastic on the outside with a 7mm opening
honestly you would never know the difference in running them unless someone told you you had a different part #
houston is offline
Old 09-16-2011 | 04:56 PM
  #5727
camocowboy's Avatar
Originally Posted by losi_racer
last weekend i wasnt impressed with the X7 at all. it was getting out powered everywhere, off the line and on the straight. Just sayin what i saw, i have no personal experience either YET
Just to clear this up since someone who has never had an engine from Monty, let alone an engine modded and broken in by Monty decided to comment. The X7 mentioned was mine. I as the driver had no problem with its performance. It has made exceptional power at the nats in cali when it was brand new, at the regional race in utah over a mile high, and back here in AZ at the Nitro Pit and Fear Farm. On the night in question it was taken from the shelf after about 3 months of collecting dust and no love and thrown on the track. The truck it was in wasn't perfect, the clutch surely wasn't perfect, and mostly likely the tune was close but not perfect. It started right up, ran all night no problem, and I got third in the main behind a full sponsored driver and Losi Racer. I would not attribute his success to my lack of motor but rather to a great drive and setup ride with a fair amount of track time. Not sure why if I'm happy with my motor someone else needs to worry about it. Just Sayin'. So if you thinking about one of these motors go ahead and indulge. I have been very happy with it. And it's getting right at ten minutes of run time here in the summer with that safe tune. Should go well over that in a month or two.
camocowboy is offline
Old 09-17-2011 | 07:22 AM
  #5728
houston's Avatar
houston is offline
Old 09-17-2011 | 07:53 AM
  #5729
teamlosi906's Avatar
Monty my buddy has a nova 821 motor,will a 421 p/s/r fit into it?? I dont know what the diff between the two are.Thanks
teamlosi906 is offline
Old 09-20-2011 | 09:36 AM
  #5730
houston's Avatar
ya , they are basically what i would call the same engine
lmk if you need anything
houston is offline
