Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 07-24-2011 | 07:16 PM
  #5566
houston's Avatar
Originally Posted by JoeC
Hey Monty, what are the carb settings for race tune on a plus4C? I want to see if I am in the ball park with were I am at. Also does the OD 97t work as well as the c6tgc?
There is no way I can answer that but a good base setting is 4.25 lsn and 3.25 hsn ,
Pipes/plug/clutch/fuel/chassis/clutch etc. are all factors
houston is offline
Old 07-25-2011 | 05:58 PM
  #5567
bcr500's Avatar
Hey bro what is the stock needle settings on a 2009 p5xlt?I think I got out of wack somewere lol.
bcr500 is offline
Old 07-26-2011 | 07:27 AM
  #5568
Trevor Williams's Avatar
R/C Tech Elite Member
sup Monty, hope all is well.
Trevor Williams is offline
Old 07-26-2011 | 08:46 AM
  #5569
houston's Avatar
Start lsn 4.5 hsn 3.25
houston is offline
Old 07-26-2011 | 08:47 AM
  #5570
houston's Avatar
Thinking about byrons challenge at dirtburners
houston is offline
Old 07-26-2011 | 11:27 AM
  #5571
PERROTTO's Avatar
Hope to c u there Monty!
PERROTTO is offline
Old 07-26-2011 | 07:28 PM
  #5572
houston's Avatar
We shall see bro
houston is offline
Old 07-26-2011 | 10:40 PM
  #5573
if you do, I'll be there.
Old 07-27-2011 | 08:40 AM
  #5574
Called and talked to Monty last night for the first time. Never met the man before but he talked with me like we were old friends. He answered all my questions and didn't try to sell me something I didn't need. Thank's again Monty. Order is in can't wait to start breaking it in.
By the way your watch is 2 min. fast
aj slidways is offline
Old 07-27-2011 | 09:32 AM
  #5575
teamlosi906's Avatar
monty what is the total head shim thickness on the plus4 c Im putting new ones in,but mine has 2 aluminum only no copper. I bought this motor new from here.My team version has 2 alu and 1 copper. Thanks
teamlosi906 is offline
Old 07-27-2011 | 01:31 PM
  #5576
houston's Avatar
New engine with no copper shim?
R u sure its not stuck between the two aluminum?
If not we will get ya taken care of
.80mm total
houston is offline
Old 07-27-2011 | 01:34 PM
  #5577
houston's Avatar
Funny steve
And thanks for the kind words , it means alot
houston is offline
Old 07-27-2011 | 03:25 PM
  #5578
kgombe's Avatar
MONTY IS SIMPLY THE MAN
after the X7 of course
NUFF SAID
kgombe is offline
Old 07-27-2011 | 06:27 PM
  #5579
bcr500's Avatar
Well I was right there in that rang,and then i noticed my clutch was hanging up some.My flywheel nut come loose and was pushing out on the clutchbell.
bcr500 is offline
Old 07-27-2011 | 06:45 PM
  #5580
bcr500's Avatar
Ok guys its time for just allittle feedback..More feedback to come when it hits the track with a race tune.
To start off I have a hott mod p5xs that runs awsome to compare to.
Ok so I bought a p5xlt and sent it to monty for his tune including the +4c crank,17011 bearing,and ceramic rear bearing.
Im at about 1 gallon mark and its realy starting to come alive and at this point already feels faster then my p5sx its alot smoother and realy puts the power to the ground!I run the exact setup with both the engines but the hes p5xlt sounds totaly differant,it just sounds and feels very strong,alot stronger then the hott mod p5xs.I can not wait for this thing to drop its nuts,it will be a total beast with smooth power from bottom to top!
Do not be afraid to get this combo for a buggy because it just feels right at home in one!Very smooth! Thanks Monty
bcr500 is offline
