Houstons Engine Service H.E.S.
#32
How will the p5xs preform with the Dynamite Platinum 053 Midrange pipe?
You mentioned the square header from OFNA with this pipe, is there a big difference over the header that comes with the Dynamite?
#34
lots of punch and a nice pull all the way through the top , the medium round header makes the top end very flat .
#35
perfect
plugs, i usually use odonnell anymore odo77T/97T w/ turbo or odo77/99 w/ standard . i am going to use nova AGAIN this summer to see if everything got figured out
ultra c5 standard the stock plug is good
#36
do you think the square header from the OS T2050 pipe is similar to the ofna one you are referring to??
#38
#39
#42
i understand graves . the only problem is i dont want to get so big that i lose my personal touch by getting too many customers . i want to be able to know everybody by name and remember everything about their rc story . i have about 50 customers now and it is starting to get difficult
starting
starting
#43
Whats the major difference with the Plus 4 vs. Jp B5 ???
can I get 10 mins out of the B5 ?
Which one will work better in Truggy ?
I also have access to a 421B probably needs to be freshened up pinched,bearings,etc.
Is that a smooth engine and how about mileage on it ????
sorry to have so many questions....
#44
b5 or b5n ? p4 is a smooth 4 port , a b5 is a p5x in jp form
10 min. maybe but wouldn't rely on it to win
6.5mm restrictor at 250 w/ 9853 and 41001 or 41005 (square headers) and then you can rely on 10 min. . the p4 is a very smoooootthhh engine but still maintains a low end grunt that as most say feels electric motor like . 421b is a great powerhouse of an engine , 821b is the same porting but better block porting to maximize the port design . if the crank is good and the p/s still have some slight pinch it is worth it .
#45
standard B5 its has the smaller bearing but has filled crank.... does it have more or less bottom than say a Plus 4 ?? I also have a p5x a guy at my local track hated it and gave it to me, besides bearing any major difference from P5 ? sleeves look exactly the same ... how do you feel about turbo buttons on both of those motors ??
22Likes
