Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 09-22-2009 | 08:24 PM
  #1531
Buzz3's Avatar
Originally Posted by houston
thanks for the offer buzz but i only work on novarossi bro
That's what I figured but I wanted to throw it out to you as well in case you had an idea on something to drop in it. Maybe a NovaGRP monster. hehe Thanks for the reply.
Buzz3 is offline
Old 09-24-2009 | 11:13 AM
  #1532
losiracer78's Avatar
Just wanted to say a big super thank to Monty and Houston Engine Services for everything they have done for me. All i can say is great and thank you very much.
losiracer78 is offline
Old 09-24-2009 | 12:29 PM
  #1533
houston's Avatar
no prob matt
houston is offline
Old 09-26-2009 | 10:36 PM
  #1534
houston's Avatar
sorry buzz
houston is offline
Old 09-28-2009 | 07:14 AM
  #1535
Trevor Williams's Avatar
R/C Tech Elite Member
got my SS 9853 and 41005 bro, thank you!.........text me your mailing addy today again please
Trevor Williams is offline
Old 09-28-2009 | 07:23 AM
  #1536
houston's Avatar
Yextin ya now
Check your pm box
houston is offline
Old 10-02-2009 | 07:40 AM
  #1537
houston's Avatar
Engines in stock at www.houstonsengineservice.com. check out the new pricing while you're there
Thanks guys ,
Monty
houston is offline
Old 10-02-2009 | 01:01 PM
  #1538
Default Checking for air leaks
Can someone tell me the best way to test for air leaks on an Rc Motor? Say with a full size car we would spray carb cleaner around the card etc to see if the engine changed RPM. I tried this with contact cleaner around the carb base and the motor died. Put auto silicone just a little around the bottom of the carb and it fixed that area. Went to spray it around the bearing and same thing happens motor dies. Does this mean that the front bearing is gone, or by doing this is something else happening?
airsiler is offline
Old 10-02-2009 | 01:05 PM
  #1539
Zerodefect's Avatar
Put fuel line on carb, hold finger over exhaust port and carb intake.
Submerge under water in sink or Holy Water basin thingy at Catholic church (for OS engines).
Blow into fuel line. Look bubbles.
Never tried the squirt WD40 on the front bearing to see if it stalls due to a leak bit.
Zerodefect is offline
Old 10-02-2009 | 04:03 PM
  #1540
tallyram's Avatar
lol!!!!
tallyram is offline
Old 10-02-2009 | 04:24 PM
  #1541
Thanks for the help Zerodefect. Allthough I do not have any holy water the sink work great the bubbles looked like a fish tank pump going off. So I guess the contact cleaner also worked got me to ask the question anyway. Know all I have to do is find out the bearing sizes for the front and back bearings.
Thanks to everyone on here for all your help.
Bill Siler
airsiler is offline
Old 10-02-2009 | 04:25 PM
  #1542
That man did not just call me Bubbles did he???
Joey Platinum is offline
Old 10-02-2009 | 04:43 PM
  #1543
Zerodefect's Avatar
Holy water cow! You got alot of Joey Platinums out of your front bearing when you blew into it.
I'd say thats a smokin gun. I just dipped my engine to test this theory. My WS7III-no Joey Platinums. N21b- maybe a little Joey Platinuming but its still good.
Old 10-02-2009 | 04:46 PM
  #1544
Yes i check my Toro as well and it is not as bad but still looks like a mini fish tank. Still more than i think it should be.
Monte, is it possible for you to call me. I need bearings for my Plus 4 and Maybe my Toro Nero motor I see you have the TKO bearings was wondering what the price is on them? What size of bearing is the front and the back on these motors. The Plus for is a new motor bought about 3 months ago. Is it normal for these bearings to go out so soon. The Plus 4 has maybe 1 ½ gallons through it and the Toro has has like ¾ of a gallon through it.
\Bill siler
661 435 3634
airsiler is offline
Old 10-02-2009 | 04:52 PM
  #1545
Zerodefect's Avatar
Might want to switch to Sidewinder or Byrons....
It isn't likely to kill NR bearings that fast. Something must have helped em die?
