Houstons Engine Service H.E.S.
#1683
Houston, can you help me understand flame outs? I run an RB C6. I switched to #77 Odonell plugs per your recommendation and took my gas cooler off and have not had a single flame out since June. I am on the east coast and the temps are dropping into the 50's and 60's. My engine temps have been rising as the dense air leaned out my mixture. I thought I had it adjusted perfect this past weekend. Not a flame out all day and temps in the 240's. Then in the main, just a ghost flame out in the middle of track while running 8 minutes in. Still plenty of fuel. Restarted and flamed out in same spot so I packed it in, While street tuning tuning today, I had another. Do hotter, lean condiitons lead to flame outs? It is not a rich condition causing these I am pretty sure. My carb gap is almost 1mm or a bit under. I only have a couple of more weekends left and want to enjoy racing, not frustrating flame outs! Thanks!
#1684
#1685
i would be rich if i could figure that out and prevent it .
overlean low speed with too small idle gap can cause FO , not enough fuel to keep engine running .
intermittent glow plug ignition
lack of pipe pressure , causing overlean conditions
lets just say there are many reasons why flame outs happen
overly rich low with too low of idle gap is also a pretty coom one as well as bad fuel with lack of nitro .
#1689
Depends on what you want out of it , 9886/41021 works very well as does the dynamite086hs . If you want more torque try a 9853SS/41005 and if you really want .more low end use 9853SS/41021 . There are a few good pipes that work well with novarossi designs and these are it .
The newer 9901SS is seeming to work very well and yields great run times. The older 9901 lacked serious topend , apparently there has been a change to the internals of the pipe .
#1690
They do what they are designed to do for sure but is just another place for an issue to arise within the fuel/pressure delivery system.
I am not saying they do not work by any means , you need to find a really good place to mount it though
#1693
Monty is a great guy and helps out a lot answering questions on here great person to do biz with for sure. When no one else could find me a 9901ss when they were out of stock everywhere Monty was the the only one that came though. A+++ customer service.
#1694
if you guys need a plus4 or plus4 C lmk asap , i have some in stock and if need be i can order more
need to get on it quick though
also have 3 ports availkable
no more r2r until i get caught up , got 4 to do at the moment
22Likes
