Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-13-2010 | 04:29 PM
  #4291
Trevor Williams's Avatar
R/C Tech Elite Member
I will
Trevor Williams is offline
Old 12-14-2010 | 06:47 AM
  #4292
so, what's up with Monty and H.E.S.? You and the family all ready for X-mas? Jingle Bells to the Houston family, tell pops I said what up, maybe we can do Sweet Home again this summer.....hahahaha
Old 12-14-2010 | 08:10 AM
  #4293
Chad Millikan's Avatar
What's going on across the pond. A bunch of big name drivers leaving Novarossi. And earlier this year one of the big wigs leaving. What's happening
Chad Millikan is offline
Old 12-14-2010 | 05:39 PM
  #4294
hambone's Avatar
Default 17011 Bearing
Monty, since you're in the Nova loop, i have a question on this bearing. I understand it to be the best steel front bearing, but my question/concern is the 6.3mm depth compared to the 6.0mm my engines come with. That's .012" and is it just the added thickness to the outer race or is the inner race thicker also. Just wondering what it does to crankshaft endplay. Why the xtra .3mm, for the double outer seal? Thanks, Rob Hamm.
hambone is offline
Old 12-14-2010 | 06:50 PM
  #4295
houston's Avatar
it is just for the inner race so you don't need spacer behind flywheel
houston is offline
Old 12-14-2010 | 07:29 PM
  #4296
hambone's Avatar
Ok, never had to use a spacer. Maybe that's just a losi flywheel thing. Just so i understand, the inner race protrudes out the front an xtra .3mm? I still have 2 nova based engines, The old trusty JP FX21 B8 and a RB C6 USA. The RB had too much thrust play in the crank for my liking and this sounds like the perfect fix. Rod starting rubbing the backplate a little much. I need to put a front bearing in my B5 and wanted to make sure it will work. Thanks for your help and if you get time pm me the 17011 cost. I will need 2. Thanks again.
hambone is offline
Old 12-15-2010 | 11:57 AM
  #4297
houston's Avatar
call me rob
503 544 6624
houston is offline
Old 12-15-2010 | 11:59 AM
  #4298
houston's Avatar
HO HO HO !!!
trying to get all settled in to the new house , still gotta pack up the basement/shop and setup in the new "man room"/shop at the new house
hope all my customers can bare with me for a lil bit here , i got engines on the bench that wont get worked on until i get into the new shop area , hope you guys understand and if you need anything or want to talk , you guys got my number
that would be cool on the sweet home jamboree or some other portland area date .
houston is offline
Old 12-16-2010 | 04:58 PM
  #4299
houston's Avatar
moving sucks!!!!!
houston is offline
Old 12-16-2010 | 07:48 PM
  #4300
I hear ya brother. I moved back earlier in the year myself and never thought I had so much junk. I'd rather slam my weenie in a sliding glass door than move and especially help someone else...now that's even worse.
Dirtdobber is offline
Old 12-16-2010 | 09:26 PM
  #4301
houston's Avatar
Ouchˇ!
Almost done though
houston is offline
Old 12-18-2010 | 10:01 AM
  #4302
houston's Avatar
What big wig are you referring to?
houston is offline
Old 12-18-2010 | 10:13 AM
  #4303
Quoted from neobuggy. Back in April we covered the departure of former head Federico Barchi from Novarossi - perhaps this was an early signal of times changing once again at the Italian engine giant.
Old 12-18-2010 | 02:26 PM
  #4304
good to hear Monty, I hear you on the moving thing......hahahaha....jingle bells and talk to you soon!
Old 12-18-2010 | 08:02 PM
  #4305
houston's Avatar
Federico has been out of the loop and on the go for a little while already
houston is offline
