Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-26-2010 | 01:43 PM
  #2791
Originally Posted by houston
artistically?
mods for looks?
its all about the mods that matter !!!
if the FMS engines were available i would love to help you out but they arent Dennis
i do have a nib plus 21-7bt that will push an rc car around the track fairly well
Art is in the heart. Not some crap on the wall When my pulse starts racing, that's art. I'll hold out for the FMS. I was able to get 11 minutes that weekend.
3DRCRACER is offline
Old 03-26-2010 | 02:39 PM
  #2792
Lille-bror's Avatar
Originally Posted by Karlos Loboss
Houston,
The other day at the track(Australia)we were having a discussion about 25% & 30% fuel as to which one would be better on fuel economy, could please clear this up for us, I always believed that 30% was more economical.
Karl
Hi.
Nitro needs A LOT more oxygen to explode compared to methanol. That is why you have to lean the HSN, when you eg. go from 25% nitro fuel to 16%.
An engine will always use X amount of oxygen at a certain RPM, no matter what fuel you use (more nitro gives no more RPM's). That is why you have to mix more high nitro percent fuel with the oxygen, to make it explode.
RB makes 45% fuel and says it will make longer runtimes compared to lower nitro percents. The only reason why that should be true is, that the fuel will make a more powerfull engine, where you don't have to open the throttle as much as with less nitro fuel, to get the same power...
I would go for less nitro (25% instead of 30%). Your engine will last longer and you save a lot of money.
Cheers
Lille-bror is offline
Old 03-26-2010 | 02:58 PM
  #2793
houston's Avatar
going out of town for a few days , be back saturday night . probably check in on the mobile every so often guys .
thanks ,
monty
houston is offline
Old 03-27-2010 | 10:01 AM
  #2794
mblgjr's Avatar
Hey Hotrod get in touch with me when you can with a little update
mblgjr is offline
Old 03-27-2010 | 11:00 AM
  #2795
houston's Avatar
I'll get to it tonight matt
houston is offline
Old 03-27-2010 | 11:46 PM
  #2796
mblgjr's Avatar
Great; mostly just wanted to know that you got it
LMK how it goes
mblgjr is offline
Old 03-28-2010 | 10:49 AM
  #2797
houston's Avatar
LMK how it goes
never have any problems with usps
international postage can be a little silly sometimes but its the nature of the beast
houston is offline
Old 03-28-2010 | 11:27 AM
  #2798
Maximo's Avatar
Originally Posted by Lille-bror
Hi.
Cheers
actually nitro needs 1/7th the amount of O2 to burn then methanol..... that is why Nitro has so much more capacity to make power..... even tho nitro actually has half the BTU's of methanol you can burn so much more nitro that you end up making more power... As you say an engines O2 intake is pretty much fixxed, so the only way you can make more power is find a fuel that requires the least amount of O2 to combust........
Maximo is offline
Old 03-28-2010 | 12:16 PM
  #2799
Lille-bror's Avatar
Amen to that, Maximo.
Well writen, and we have got an another view to the question
Personal I have a hard time finding out why you will need all that nitro in a off-road car: If you haven't got a bluegroove or carpet track, you end up making a lot of wheelspin with all that nitro. Go down in nitro, and always use hard springs in the clutch. If you have too much wheelspin, use a bigger bell (and gain even longer runtimes). If the gearing now is too high, and the engine doesn´t come up in max. RPM at the end of the straight, you should use a shorter header to reduce the bottom power, and stick to the first bell.
Old 03-28-2010 | 01:04 PM
  #2800
houston's Avatar
Interesting view ?
houston is offline
Old 03-28-2010 | 01:38 PM
  #2801
Lille-bror's Avatar
Hi Monty
Wouldn't you be a fool, if you tamed your engine power in a flaccid clutch, if you could translate the power into more topspeed and visa versa???
Please convince me that I'm wrong
Old 03-28-2010 | 03:41 PM
  #2802
houston's Avatar
Hi Monty
i understand the mechanics of a clutch and how to tune the clutch to track conditions lil bror .
the interesting part is the gearing and how final rollout (gear ratio) effects the engine and its power production . the 32 pitch gears we use for 1/8th scale have a pretty broad spread from one gear to the next so it is a little harder to dial in then a 10th scale is . a lot of thought has been put in to the gear ratios on the 8th scale vehicles before they have been released to the public and is usually pretty darn good some buggys have different ring/pinion gear ratios (associated uses truggy gears) and that lets you use large clutch bells with more gears on them , good concept? seems to work fairly well
we are all fools
i for one would love to tap into the vast amount of friction materials that are out there and apply them to our rc vehicle clutch shoes impulse rc
two cents worth and just a ramble
houston is offline
Old 03-28-2010 | 06:10 PM
  #2803
r1harper's Avatar
Hey bud...we ran the "special" tuned Houston engine again today....and 10 minutes to a tank every time..we can go 11 with it if need to...she is coming around...thanks again
r1harper is offline
Old 03-28-2010 | 07:12 PM
  #2804
houston's Avatar
good to hear Wes!!
i hope it lasts you guys a long time!!
houston is offline
Old 03-28-2010 | 07:43 PM
  #2805
what up monty
ran your motor in buggy today 11:44 on a tank
tried the 9886 with 21 header that thing is a beast compared to 9901
it pulls everywhere
icemandolmite is offline
