Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-28-2010 | 07:46 PM
  #2806
houston's Avatar
Originally Posted by icemandolmite
what up monty
ran your motor in buggy today 11:44 on a tank
tried the 9886 with 21 header that thing is a beast compared to 9901
it pulls everywhere
86 pipe makes lots o power for sure!!!!
i love that pipe , sometimes even in truggy
houston is offline
Old 03-29-2010 | 03:03 AM
  #2807
Lille-bror's Avatar
Originally Posted by houston
i understand the mechanics of a clutch and how to tune the clutch to track conditions lil bror .
the interesting part is the gearing and how final rollout (gear ratio) effects the engine and its power production . the 32 pitch gears we use for 1/8th scale have a pretty broad spread from one gear to the next so it is a little harder to dial in then a 10th scale is . a lot of thought has been put in to the gear ratios on the 8th scale vehicles before they have been released to the public and is usually pretty darn good some buggys have different ring/pinion gear ratios (associated uses truggy gears) and that lets you use large clutch bells with more gears on them , good concept? seems to work fairly well
we are all fools
i for one would love to tap into the vast amount of friction materials that are out there and apply them to our rc vehicle clutch shoes impulse rc
two cents worth and just a ramble
Hi.
Year, I know you are the expert. I'm not trying to say anything else
Here is the gearings you can make on a XRAY buggy:
As you can see, the steps are really small when it comes to bell/center diff ratio.
Cheers
Lille-bror is offline
Old 03-29-2010 | 08:35 AM
  #2808
houston's Avatar
Originally Posted by Lille-bror
Hi.
Cheers
I am perpetually learning what I can about the toy cars I like to play with
Ya , you are able to go in small increments if you change spur and clutch bell combos but just changing clutch bell a tooth changes the gear ratio quite a bit and chenges all the characteristics of the engine
Just changing the clutch bell is what most people do
houston is offline
Old 03-29-2010 | 12:24 PM
  #2809
Lille-bror's Avatar
Cool Monty
Another question:
Is the 41005 shorter than a 41021 header?
What about he 41001?
... Or is it just the shape that makes the difference?
I would like to try a header, that is approximate 1 cm shorter than th 41021.
Cheers
Old 03-29-2010 | 01:02 PM
  #2810
houston's Avatar
Cool Monty
Another question:
Cheers
ya the shape of the header makes a pretty big difference in the effect the exhaust has on the engine .
1 cm shorter than the 41021 ? i would say try the ofna/jammin round header , i believe it is a little shorter than the 41021 .
the double bend headers from short to long 41019 , 41001 , 41005
try evrything and educate yourself , this will allow you to see what works best for you remember after you change pipe/header you will have to retune the engine
houston is offline
Old 03-29-2010 | 02:16 PM
  #2811
rceefreak's Avatar
How's things goin on the left coast with the mill Monty?
rceefreak is offline
Old 03-29-2010 | 04:57 PM
  #2812
houston's Avatar
i am waiting for the p5xlt tuned to come in and see what it has inside , i will get with ya when those come in and we will discuss which engine you might like
monty
you got my number if you want to talk about it
houston is offline
Old 03-29-2010 | 07:34 PM
  #2813
Hey Monty, I got an unusual problem w/ my Toro. A few races ago it went crazy rich in the middle of a race and couldn't figure out why. Had a new TKO front bearing put in and had it pinched while it was apart figured it couldn't hurt. Last week I was letting my dad run it, and during his race it did the same thing. It was so rich and happened so abruptly, I at first thought the throttle linkage was getting hung up and not opening all the way. I ended up leaning the top 2 full turns to get it to get on the pipe. It ran fine for the rest of the race, came off the track at like 210 or so, and still a little fat. Any idea what could have caused it.
Miniracer23 is offline
Old 03-29-2010 | 07:39 PM
  #2814
IF U RUN HB CHANGE YOUR TANK
IM NOT MONTY BUT I BET THATS THE PROBLEM
icemandolmite is offline
Old 03-29-2010 | 07:43 PM
  #2815
I thought that too. checked the tank for leaks and found none.
Old 03-29-2010 | 07:48 PM
  #2816
allan42r's Avatar
are you guys getting over 10min of run time with the toro ? i know many things = run time.
allan42r is offline
Old 03-29-2010 | 07:52 PM
  #2817
FILL YOUR TANK AND TURN IT UPSIDE AND SEE IF IT LEAKS FROM THE LID
Old 03-29-2010 | 07:57 PM
  #2818
houston's Avatar
listen to LA (icemandolmite) he runs hot bodies and has had the same thing happen to him . there is nothing in the engine that could go wrong and cause 2 full turns out of wack tune
houston is offline
Old 03-30-2010 | 05:06 PM
  #2819
houston's Avatar
the tuning bible has been edited with even more knowledgeable tuning tips !! check it out !!
houston is offline
Old 03-30-2010 | 05:56 PM
  #2820
I wasn't able to find a leak. pressure checked my tank and filled it with fuel to check it. I'm gonn replace it anyway. Just curious though, I would think a leaky fuel tank would cause a lean condition, not rich?
