Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-03-2010 | 10:11 AM
  #4231
houston's Avatar
Originally Posted by kgombe
Monty..
2 green carbon shoes
2gold aluminum shoes good setup?
planning on running both flywheels on my truggy at motorama just to try out which one feels better and for run times also... maybe running the plus 4 at that event.. not enough time on the FMS to try it there on an indoor track in the dead of winter.. i'll only be running truggy and maybe pull out the revo at this event
those were my thoughts on clutch setup , very similar to what the boys run in the losi camp which that clutch setup is dialed so..............
Good call on the FMS , it is probably still pretty darn tight huh? How much fuel did u get through it ?
FMS especiale'
houston is offline
Old 12-03-2010 | 10:14 AM
  #4232
kgombe's Avatar
FMS especiale'
just over a half gallon after doing your break in method....
just checked it.. yep its still tight....
kgombe is offline
Old 12-03-2010 | 10:38 AM
  #4233
houston's Avatar
total amount of fuel?
and
houston is offline
Old 12-03-2010 | 10:47 AM
  #4234
kgombe's Avatar
and
lol... ummh 1 gallon and a quart to be exact...
kgombe is offline
Old 12-03-2010 | 10:51 AM
  #4235
houston's Avatar
it is a team FMS so it should start to loosen up around 1.5-2gallons
houston is offline
Old 12-03-2010 | 10:57 AM
  #4236
kgombe's Avatar
i got it.. i also got the back plate you told me about ..so im anxious to try it out when it gets warm again
kgombe is offline
Old 12-03-2010 | 11:20 AM
  #4237
houston's Avatar
round buttplate = more low end torque with a lil loss in top end , just a little
houston is offline
Old 12-03-2010 | 11:23 AM
  #4238
kgombe's Avatar
hmnnn.... not really a fan of to much bottom end... but we'll see how it goes.. only one way to see if i it with this engine is to test it out...
kgombe is offline
Old 12-03-2010 | 11:27 AM
  #4239
houston's Avatar
very true
just be careful to have the piston up while you pull the buttplate off
i have done it once and never again !!!
houston is offline
Old 12-03-2010 | 11:35 AM
  #4240
kgombe's Avatar
very true
hahahaha.. u killing me.. PISTON UP.. BUTTPLATE OFF... try to rephrase please...
yeah i did it once before myself... but on a cheapo motor
kgombe is offline
Old 12-03-2010 | 11:48 AM
  #4241
Rick57's Avatar
Hi Monty,
Should there be any crankshaft end play on a plus4 with no flywheel? If so, as you tighten the flywheel down should most of it go away?
Rick57 is offline
Old 12-03-2010 | 11:57 AM
  #4242
kgombe's Avatar
in and out play is normal... and should go away as you tight the flywheel
kgombe is offline
Old 12-03-2010 | 12:40 PM
  #4243
houston's Avatar
Originally Posted by Rick57
Hi Monty,
yes and yes , if the crank moves in and out easily that is a good sign , means the bearings in the block are aligned good
houston is offline
Old 12-04-2010 | 11:59 AM
  #4244
Chad Millikan's Avatar
Hey monty. Got a Q for ya. On the rear bearing. Does the plastic retainer go towards the carb or towards the back plate. And when I sinch down the clutch nut the rotation feels gritty. I havetried different collets and put a washer behind the collet, nothing resolves it. The p5xlt has about 1.25 gal. Through it
Chad Millikan is offline
Old 12-04-2010 | 12:09 PM
  #4245
kgombe's Avatar
replace both bearings if it feels gritty
and as for the orientation of the rear bearing... when you look at the bearing from the back plate... you should see the balls should be exposed... so the retainer should face the carb...
kgombe is offline
