Houstons Engine Service H.E.S.
#4203
Wait untill you try the Monty tuned FMS
will be turning,like really fast.
#4204
#4207
the newer Super Strong pipes gets too hot to touch but not usually melting the mud guard hot
hmmmm
#4209
Which plug is recommended for the N21R-BF? This will be a cold weather application 30-50 degrees running Byron's 30% fuel. Also, would you recommend 9% or 11% oil content for fuel? Thanks for the help as I am new to Novarossi line of engines.
#4210
Do you think perhaps late combustion timing could cause more exhaust heat?
#4211
The ofna 086 isn't exactly the highest quality pipe on the market and gets plugged up pretty quick , I have ran many of these pipes to know what they do . They run phenomenal for the first gallon then build up carbon and lose performance , as does any pipe but these ones especially .
Hope this helps
Btw , I don't recommend usin an 86 based pipe on the FMS
#4213
#4215
22Likes
