Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-27-2009 | 12:18 PM
  #16
BigNasty's Avatar
wassup, monty!
BigNasty is offline
Old 03-27-2009 | 12:49 PM
  #17
mfrosty's Avatar
Man did you open a can of worms here Monty, you better check this thread often or you're going to get WAY behind in questions
mfrosty is offline
Old 03-27-2009 | 02:40 PM
  #18
carkingaz's Avatar
I race where it's really dusty and sandy.. Should i use a air filter??
Inside Joke!
Monty is good people would trust him a 100% with any of our stuff! Dude knows motors!!
carkingaz is offline
Old 03-27-2009 | 03:04 PM
  #19
stavman's Avatar
MY BRUTHA
Wass Uppppppppppppppppp
stavman is offline
Old 03-27-2009 | 03:08 PM
  #20
houston's Avatar
Originally Posted by RGraves
1.) I am running byrons 20%. How many shims should I use? I have a V-Spec, WS7II, S7 and C6. Saving my money for a new Nova
2.) What is the advantage to running turbo plugs?
3.) What range plug is best for 20% fuel
3.) What makes a crank wear, heat?
4.) How many times can a engine be pinched?
dont run vspecs
buy a novarossi and you will be happy
turbo plugs have better seal in the plug seat and a better flow of the combustion ball or detonation ball to expell the exhaust faster creating more power
use a hotter plug with lower nitro content but also depends on humidity , altitude and such of your area
shear friction and lack of lubrication heat will mess up the rod and make it lose its temper no really the rod will start to lose its temper above 300 or so and you will end up with a broken rod or bushing failure sooner or later
and besides that , think about how much a rod really gets stressed . alot
Originally Posted by Garrison
i picked up a 821b during the winter. was wondering what pipe i can run to get alittle better low end. motor is 821b with a seven insert, i run 30% byrons. havent changed the glow plug yet. but i run a jp3 pipe, thanks for the info ahead of time
jp pipes are not the pipes for novarossi engines , trust me
since you already have the right header i would recommend buying a dynamite 086hs pipe only you will be happy guaranteed
Originally Posted by toofast55
what is a good high low needle starting point for the plus 4 im aware it will vary from one location to another just something avg to work off of.
idle gap at 1mm , low approx. 1 3/4 - 2 turns out , high approx. 3 1/2 -4 turns out , base race tune but not alll engines are like this , anomaly engines like to be about 1.5mm gap , low 2- 2 1/2 turns out , high 2 3/4 -3 1/4 turns out , cant tell ya why .
Originally Posted by looneytune
I read in another topic that you like the P5XS as one of your favorite truggy engines. I run that engine in both my buggy and truggy with the Nova 9886 pipe and short header. Is that the pipe your are using in a truggy or should I try a 9856 with the same header for more punch? I also have a longer header. I understand that longer headers will produce better bottom end at the expense of some run time, if that is correct? Also, what carb restrictor would you recommend for the buggy? I'm tying to take some of the power away so I can control it better. I have the stock restrictors in both engines now. How do the L or " ] " shaped headers affect performance and runtime? The only pipe I ran with that type or shape of header was the OS T-2050 on a V-Spec which hit pretty hard in the middle. Is that a characteristic of this type of header shape? Thanks. You said to ask questions and I usually have a lot of them.
two pipes i use 95% of the time are dynamite 086hs pipeset w/ header and 053mr pipe with the square header from ofna . novarossi perform the best but but $$$$$$ i ain't rich!!! try a plus 21-5(plus4) in the buggy , much smoother you can use restrictors to gain runtime but some designs of engines actually gain power from smaller res. as it creates a better air/fuel mixture i usually leave the 8mm in unless i need some runtime
Inside Joke!
thanks todd , stay cool bro
btw , i still need parts
houston is offline
Old 03-27-2009 | 03:53 PM
  #21
doubletap's Avatar
monty is a nice guy, he's helped me at the nitro pit, hope he can help again!
doubletap is offline
Old 03-27-2009 | 07:31 PM
  #22
houston's Avatar
i would have got ya goin but your car broke butch
houston is offline
Old 03-27-2009 | 07:55 PM
  #23
Can you buy just the Ofna square header only?
Fugate is offline
Old 03-27-2009 | 11:04 PM
  #24
Jaz240's Avatar
Yes...call Nitrohouse 1800-928-0304..tell them you want the Header only for the 053 one piece pipe, its about 30$..Not sure the part number
Jaz240 is offline
Old 03-27-2009 | 11:30 PM
  #25
houston's Avatar
i probably have one or two laying around
houston is offline
Old 03-27-2009 | 11:54 PM
  #26
motomanpat's Avatar
Monty is the most helpful guy I have ever met at the track,almost to the point that he scraps his own races to help people outoh ya thanks again for the last minute battery pack that was charged and ready that you just happen to have in your pocket last year. If I was only fast enough to need a faster motor you would be the man I would ask. See you soon buddy!
motomanpat is offline
Old 03-28-2009 | 10:43 AM
  #27
i have a axarossie motor that the bottomend let go why did the bottomend let go
6428hotrod is offline
Old 03-28-2009 | 11:03 AM
  #28
diamondracing's Avatar
I wasn't real impressed with the way you smoked Cigars at Nitro Challenge I expected more out of you BTW I bought a P4 and stopped running RB.....
diamondracing is offline
Old 03-28-2009 | 11:20 AM
  #29
houston's Avatar
ya ok mister
and whats wrong with a cigar here and there
nice job on the switch brotha' don
houston is offline
Old 03-28-2009 | 11:22 AM
  #30
houston's Avatar
those axe rossi conrods are garbage it broke i am sure
they are milled all kinds of funky
houston is offline
