Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-04-2009 | 09:16 AM
  #166
houston's Avatar
Originally Posted by morfn321
Houston, Thanks for the reply. I just ordered the 086 pipe set Is there a good plug that works well with this motor? Thanks for all the help. Any other info on the motor you think would be informative would also be great!!
standard odonnell 77 or mccoy mc8 , turbo odonnell 77 or 97
i am pretty sure the novarossi plugs are good now , i will be testing them out shortly .
houston is offline
Old 04-04-2009 | 09:30 AM
  #167
RCworks216's Avatar
h.e.s, whats a good pipe set for the jp FX 21-b-5n?
RCworks216 is offline
Old 04-04-2009 | 09:39 AM
  #168
houston's Avatar
just put the 2 pipe combos i recommend in your pit box and you will have all the pipes you will need
novarossi 9853 w/ 41001 or 41005 , 9886 w/ 41021 or 41020 novarossi are the best performing hands down
ofna 053 , ofna 086 w/jammin medium round header
the dynamite pipes are great with excellent durability factor but the ofna pipes perform a touch better
houston is offline
Old 04-04-2009 | 10:19 AM
  #169
053 pipes seem quite popular with p5x and many other mills.
Most often mentioned is the dynamite and ofna pipe (as a Novarossi original alternative).
How will a GRP 053 pipe hold up, compared to the other 053 pipes?
I have one, and I believe it to be the best alternative compared to my other pipes (jp2, jp4).
Any advice?
casevac is offline
Old 04-04-2009 | 10:53 AM
  #170
RCworks216's Avatar
ok thanks.
Old 04-04-2009 | 06:25 PM
  #171
Monty I got my Plus 4 thanks.
Has anyone filled the plus 4 crank? It looks like it would work good.
infanterene is offline
Old 04-04-2009 | 06:57 PM
  #172
stavman's Avatar
Mr Houston
Man yer thread is BLOWING up Buddy
Nice job
Ya gunna get any Toro Nero's in ta try. I have a couple coming in, all sold, but should be a good Mill for sure
Later buddy
Stav
stavman is offline
Old 04-04-2009 | 07:39 PM
  #173
Monty whats your thoughts on Ceramic bearings in mills, front and rear? I just put front and rear TKO's in 1 of my mills and asked around and am getting mixed opinions and stories good and bad.
malik is offline
Old 04-04-2009 | 11:42 PM
  #174
Nitro$junkie's Avatar
Originally Posted by houston
i havent tried every combo under the sun but i have tried a few as far as the 3005 goes , i believe those are efra legal pipes and are in the silencer dept.? not always the best in performance but if you need efra legal in australia then its probably a good pipe for ya . 3004 , 3005 i believe are to be modeled after the 9901 pipe . 9901 worked good w/41005 or 41020 .
ok cool so the 9901 is the hot choice for power would the short smooth flow header do the trick on both motors so theoreticly the 3005 sicne not performing power wise should be better on fuel??. also i was looking up about the plus 4 and found that the head button setups different to the Toro it dont have the new rubber seal type, why i ask is the toro i got was the standard plug version and i was thinking down the track to convert it to turbo now since the +4 im buying is going to be the standard head version and i want to convert that as well now i cant find what part number the new 09 version which come's with both use's so i was thinking is it possible to use the setup that comes with the Toro Neo T is it possible to run the rubber seal style head button on the +4
Nitro$junkie is offline
Old 04-05-2009 | 12:30 AM
  #175
houston's Avatar
Any advice?
wrong header but will be good for shorter tracks
houston is offline
Old 04-05-2009 | 12:31 AM
  #176
houston's Avatar
Originally Posted by stavman
Mr Houston
Nice job
Later buddy
Stav
got a couple coming ion when jim gets back from vegas
houston is offline
Old 04-05-2009 | 12:32 AM
  #177
houston's Avatar
which engine?
they are the best period!
houston is offline
Old 04-05-2009 | 12:34 AM
  #178
houston's Avatar
different buttons , toro turbo is part#28025 p4t is 28002
houston is offline
Old 04-05-2009 | 12:47 AM
  #179
Ok, what header do you recomend?
Any advice for a multi-role pipe, euro-style tracks (short, smaller jumps, more twisty)
For my current p5x, but also for the future (+4 and perhaps a N21BF).
Prefeably efra aproved.
casevac is offline
Old 04-05-2009 | 12:56 AM
  #180
houston's Avatar
efra legal pipes ? i dont need to play with those much here in the us so i dont really have alot of testing results to dish out . sorry casevac
the 9901 performs much like the 53 and i am pretty sure its legal ?
the 41001 or 41005 headers for 9853 but they will not work with the grp qwik connect system
houston is offline
