Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 12-31-2009 | 10:03 AM
  #1996
gixxerman's Avatar
gixxerman is offline
Old 12-31-2009 | 10:39 AM
  #1997
houston's Avatar
Originally Posted by gixxerman
Question, I ran a WS7 over last season and a half which I bought %2
Huh? Are you trying to ask if you ran 20% last year can you switch to 30% ?
No problems
houston is offline
Old 12-31-2009 | 12:38 PM
  #1998
gixxerman's Avatar
No problems
No, for some strange reason it didn't allow the whole post.
Here it goes again:
I have been running a WS7 for the last year and a half, aprox 5-6 gallons. I decided to pull the motor apart for a little PM, and noticed a proportionaly large amount of carbon build-up just on the top of the piston. After some carefull cleaning I also noticed two very small nicks in the top of piston maybe from a coil on the plug. I was wondering what caused the build-up ie. tune, fuel, wrong plugs, and if the nicks in the piston itself would hurt performance or tune. I have been running OD 77t and 97t plugs. The rest of the motor is basically spotless and it ran fine prior to tear down.
Thank you for the quick response to that partial post!!!
Old 12-31-2009 | 01:01 PM
  #1999
Representin !!!
WideOpenThrottle RC is offline
Old 12-31-2009 | 01:21 PM
  #2000
Integra's Avatar
Nice Paint Qmartin.
cool decal too Monty
Integra is offline
Old 12-31-2009 | 01:43 PM
  #2001
houston's Avatar
Originally Posted by Integra
Nice Paint Qmartin.
sweeet!!!
houston is offline
Old 12-31-2009 | 02:37 PM
  #2002
Default engine break in
Monty, when do you think you will start your breakin service again, also I assume I would send it with the clutch etc installed. I have a plus 21-5k that I think needs your touch after my last experinace with a p5x.
jet flyer is offline
Old 12-31-2009 | 02:56 PM
  #2003
houston's Avatar
probably whenever the rain stops and the temps pickup around here
i didnt realize how many engines i would run in until i stopped doing it for a while
houston is offline
Old 12-31-2009 | 02:59 PM
  #2004
Thank you, I will leave it as a paper weight for a while then.
Old 12-31-2009 | 03:59 PM
  #2005
r1harper's Avatar
Monty..what is the main difference between the new P5 T and a Plus 4..on the track. got a race coming up and i want to run the p5..but than again the plus 4 is well...a PLUS-4.
r1harper is offline
Old 12-31-2009 | 04:05 PM
  #2006
houston's Avatar
5 port has a powerband that the 4 port lacks , more raw power . depends on what crank the 5 port has in it as to how much powerband also
p5xlt / 15009t or 15007t works just fine
houston is offline
Old 12-31-2009 | 05:18 PM
  #2007
r1harper's Avatar
well i was referring to a bone stock P5XLT
r1harper is offline
Old 12-31-2009 | 05:21 PM
  #2008
r1harper's Avatar
is the 15009t what the new p5 has in it?
r1harper is offline
Old 12-31-2009 | 05:27 PM
  #2009
houston's Avatar
No, 15009. The tuned stuff costs more
houston is offline
Old 12-31-2009 | 05:52 PM
  #2010
r1harper's Avatar
gotcha..
r1harper is offline
