Originally Posted by keavze
(Post 5705253)
hi guys,
just wana find out how much difference (in terms of power) is the c6 compared with ws7? :weird: or it's a no contest at all? :lol: |
I highly doubt, the C6 has less top end than a WS7! Both have great top.
While the WS7 has very well but still well controllable bottom, the C6 is just an animal! A C6 is by far a better truggy engine than the WS7 is. |
best plug
I have the WSTL2g and was wondering which would be the best plug to run in it? I was thinking of this one: http://www.amainhobbies.com/product_...oducts_id/2226, would you recomend this one or another? Let me know what you think.
Originally Posted by triplesix
(Post 5706525)
Originally Posted by Chris__RC
(Post 5705567)
I think that is an onroad engine.....
by the way, i've a used c6 but how to tell which version is it? the prints on the heatsink are totally 'un-readable'. :lol: it uses a turbo plug and with red 7mm venturi. BBT, BBTII or BBII? :weird: on the rod there's a '05' engraved. |
Originally Posted by NitroWD
(Post 5706800)
does that mean c6 is not suitable for buggy? :weird:
With the right restrictor, it's(c6) really good in a buggy. I would never use it myself, because it could pull a 400lb person on a computer chair, but it's good if you can handle it.
(Post 5706800)
Originally Posted by Midnight
(Post 5701504)
Does anybody know the diff between the s3 l2g and the s3 II l2g? Can I use the jp3 pipe?
Originally Posted by Semple
(Post 5706887)
I agree 100% about the C6. |
(Post 5706887)
Whats the best plug for an S5? I'm using a 2035 pipe with it.
(Post 5706887)
It does have alot of power, it helped me in buggy because of fuel mileage and where other cars have to hold enough momentum wide in a turn to make a jump, I can hug the pipe and blip the throttle and make the jump, also in a timed section, if you get out of time you can recover quickly. And at one track they still use a gate drop, that C6 will put 10ft on any other car on the straight out of the gate. |
Originally Posted by slaytanic
(Post 5707575)
16% nitro
hi,
on the ws7 and c6 there's total of 0.3mm shims (usable to 25%nitro according to manual); if i wana run 16%nitro, do i have to remove 0.1mm shim or leave it alone? :sweat: |
Has anyone ever tried the turbo head on the S5. If so what are your results?
about RB 192 header, it's considered as short?
Any word on when the new motors will be in the US.
Anyone know the factory settings for the S5?
Idle air gap 0.8mm
High jet. 3.5 turns out from closed Low jet 5 turns out from closed (make sure you set this by holding the slide full open otherwise you will damage the spray bar) |
Thanks! I just rebuilt mine and was using the carb on a GO so the needles are all wacked!
Originally Posted by putterx
(Post 5711508)
Do you have to run the inserts to get that kind of run time?
I would say yes to inserts. I get about 11-12 minutes on my modded ws7 with normal plug, 25% Byrons Gen 2 race blend and #7 insert. Love my RB's I can't wait to try out my new "Hobby" 5 port when it comes in.
Originally Posted by aaron joy
(Post 5728906)
Problem with b9
Hi
I have a b9 to replace my grp tuned engine.I have broken the engine in but the engine seem to get very hot 160-180f but does not have the power anywhere near the grp which has had a full rebuild.The tried different plugs rb 6-7 better with 7 ran cooler.But does not have the top speed. Thanks |
(Post 5728880)
Originally Posted by 8&stuff
(Post 5730168)
I use no inserts at all. Its more the pipe and header that do anything on my s5 l2g. super linear and smooth.
Originally Posted by Quietman
(Post 5730080)
Hi
RB has always taken time to tune and fully break in. :eek:
There is something about the way they build there motors. 180 isn't Hot by any means for that engine, and it will take way more then a gallon before you get a good pinch in the engine, and get the carb where it needs to be. Give it some time and keep running it. B9=C6 part for part from what I have heard, so it really shoulb be a beast once its really run in. |
My WS7 is giving me some problems. I've been chasing a tune all week in preparation for tomorrow. I've been running it for a tank, letting it cool, then running it again. It seems inconsistent from tank to tank. I've been getting a lot of stalling in the higher RPM range while accelerating. The engine seems to get hotter and hotter during each tank until it's about 250 or even 260. After a few minutes, there's plenty of smoke, but the first few minutes are often much less smokey. I'm thinking my bottom is too rich and my top is too lean, but it's hard to detect because my idle is too high. I'm hoping I can get it set right before tomorrow.
Any suggestions on where I should be going with my needles? |
(Post 5730370)
Any suggestions on where I should be going with my needles? what plug are you using...try hotter plug. iv been reading on here the rb/nova plugs have been fouled. I see some c6's around but not many s7's. most rb's are similar but not the same. I know from experience the rb pipes and both 053&086 pipes from power racing or dynamite are descent pipes on my s5 l2g. the only jp pipe i would try on an s7 is a jp1. i have all jp pipes ecxept the p6 and have tried them all on my s5 and they either lack somthing or tend to run hotter than the dynamite/rb pipes. I tried the losi re11 last week and things were good but ran a little hot. when running hot i usually try richening top and lean bottom an hour. running an rb at 240degrees is fine(i have a grp that runs 60 or more degrees less). when i see 260+ after a 15 minute run i turn needles. I am believing tune by sound is better than by temp. I have have the extra shim under my button right now too. |
(Post 5730232)
Well Ive already ordered inserts 6.5, 7.5 and 8.5. i was planning on using the jp3 pipe and header or I can use a 192 header and 2020 pipe.
which other plugs fit
Hi
Apart from the rb range of plugs what other plugs can you use and which ones are the same as the rb range. Thanks |
(Post 5730906)
Hi
Hey guys getting ready to order my D8 and would like to know if there are any parts I should stock up on. How about upgrades. Heard there were some problems with the driveshafts. Fix available?
(Post 5730865)
I hear of guys running jp3's(some get lucky and are efficient)but that 2020+short header outta be nice..I read somewhere somebody was getting more than 13 minutes and it might have been with an insert. if i remember right it was on a ws7.
(Post 5731613)
Well a buddy has a jp4 and a 2045 for sale cheap. Would one of those work?
I personally have been using the Odonnel 099 plug in my S5. I have about a gallon on the plug in there now. I have used the 099 in cold weather and hot weather and it works fine.
(Post 5730865)
(Post 5731613)
| All times are GMT -7. It is currently 02:28 PM. |
