GRP... Engine... Thread...
#1756
I have 2 extra rods right now already. Thanks for the replies. i run the P3 in there already. I was even thinking the P4 at this point. I'll close up that idle and try messing with the LSN tomorrow. It's about to rain here.
I hope i can get this to work!
#1757
I just picked up a used GRP .28 MRT with grp exhuast (2053). I got it for $100 bucks and its not in the bad of shape at all.
Until i thought. I have a really high idle after high speed passes. This is my first GRP so i had to do some research to get the correct needle settings and to read about all the different things people go through. Well the guy i got it from used OS p3 which i found out after is a bad idea. Im assuming the plugs will leak. Would that be the cause of the crazy idle?
When i do a high speed pass. the engine will be revving high then it will go down after 20 seconds or so. then if i just tap the throt it will go right back up.
Well i couldn't figure it out for the longest time and it was about to just be a shelf queen at this point. I really wanted to use this mill. so i picked up new p/s, rod, pin, clips, front and rear bearings. cleaned up the inside put her back together than started her up. Well same problem. I sealed the engine's carb and backplate while it was apart too as i do with all my engines.
I still dont know what is wrong with it, maybe its the plug that im using. i just ordered a new head button so i can run the grp plugs. Im hoping that is what the problem is.
has anyone ever had this problem? If so, what did you do to resolve it.
i just got my untuned grp .21 yesterday. So if i can't fix it, im just going to swap the parts that i can with the .28 and .21.
thanks for all your help guys.
the guy you bought it from used os plugs, what did you use???
i am sick of ppl saying you cant use the os plug, because you can....i have not changed back to grp plugs....i will put one in, and i will bet it wont leak...
the os plugs are fine and about 5 dollars per plug cheaper than the grp plugs....
3.5 turns out from bottom on the hsn
idle gap 1-1.5mm
there have been some random grp parts popping up like everyone else said ...i picked up a tuned piston and sleeve nip on ebay for 65 bucks ....if anyone has a tuned rod pm me i would be interested
#1758
Zixxer, thank you man! I was so rich on the LSN. Im going to put a OD 97t in tomorrow and give that a shot and see how it runs. I can get those for like 5 bucks a pc. If they work great im in luck.
Also Zixxer, Ill check tomorrow at the shop if they have any rods left and let you know ASAP. i think they are like 30-40 bucks. Have to double check. But, i'll get back to you.
Thanks everyone for all your replies!
#1759
My tuned .21 popped a glow plug coil and siezed this weekend. I need a new motor (diff brand) or a piston and sleeve. You find anymore of those parts Zixxer? 65 bucks is still cheaper then a new mill.
#1760
#1761
Using OS P3s and im having a reakky high idle after high speed passes. i just replaced all the internals too.
I did however pick up another button from the local shop. should have it by friday. Im going to try running grps, but just hate how they cost 15 a pc.
#1762
#1764
Hey guys i bought the non tuned grp with the silver head and was wondering what plug i should put in it and is it a turbo or standard plug engine. Also if i were to find a tuned crank and psiton sleeve do i have to buy both of those for it to run properly when/if i decide to change all the internals
#1765
#1768
I just picked up the untuned myself. I love it so far! Im going to break it in then switch that brick(conrod) and maybe the crank. Then to a .21 button head and orange head. for my upgrades.
Does anyone run nitrotane with their GRPs? I took my engine apart last night to check on the wear so far and after 5 tanks I noticed that it leaves a dark brown residue on the top of the piston.
#1769
2Likes
