Like Tree2Likes
GRP... Engine... Thread...
Old 08-09-2009 | 09:32 PM
  #1741
Cory Kerber's Avatar
The seller said it's a new rod. I think it ran it a couple times that's it. So new rod, new bearings, and fresh pinch for a great price. If it lasts me 3 gallons it's paid for itself.
Cory Kerber is offline
Old 08-09-2009 | 11:29 PM
  #1742
chris1381's Avatar
I have a new piston,sleeve,rod and wrist pin. What is it worth ?
chris1381 is offline
Old 08-11-2009 | 04:45 PM
  #1743
ovalosi's Avatar
search for .21 grp on ebay. it still has a few days but there is a nip tuned rod
ovalosi is offline
Old 08-11-2009 | 05:55 PM
  #1744
Would an OD 97 or 99 work better in a Tuned running 30% in 100 degree weather?
Old 08-11-2009 | 05:56 PM
  #1745
97
zixxer is offline
Old 08-12-2009 | 09:12 AM
  #1746
j8ight13's Avatar
I just picked up a used GRP .28 MRT with grp exhuast (2053). I got it for $100 bucks and its not in the bad of shape at all.
Until i thought. I have a really high idle after high speed passes. This is my first GRP so i had to do some research to get the correct needle settings and to read about all the different things people go through. Well the guy i got it from used OS p3 which i found out after is a bad idea. Im assuming the plugs will leak. Would that be the cause of the crazy idle?
When i do a high speed pass. the engine will be revving high then it will go down after 20 seconds or so. then if i just tap the throt it will go right back up.
Well i couldn't figure it out for the longest time and it was about to just be a shelf queen at this point. I really wanted to use this mill. so i picked up new p/s, rod, pin, clips, front and rear bearings. cleaned up the inside put her back together than started her up. Well same problem. I sealed the engine's carb and backplate while it was apart too as i do with all my engines.
I still dont know what is wrong with it, maybe its the plug that im using. i just ordered a new head button so i can run the grp plugs. Im hoping that is what the problem is.
has anyone ever had this problem? If so, what did you do to resolve it.
i just got my untuned grp .21 yesterday. So if i can't fix it, im just going to swap the parts that i can with the .28 and .21.
thanks for all your help guys.
j8ight13 is offline
Old 08-12-2009 | 09:55 AM
  #1747
tooo lean on the top
lovell is offline
Old 08-12-2009 | 10:12 AM
  #1748
Matt M.'s Avatar
Administrator
the guy you bought it from used os plugs, what did you use???
i am sick of ppl saying you cant use the os plug, because you can....i have not changed back to grp plugs....i will put one in, and i will bet it wont leak...
the os plugs are fine and about 5 dollars per plug cheaper than the grp plugs....
Matt M. is offline
Old 08-12-2009 | 10:23 AM
  #1749
j8ight13's Avatar
I'd rather use OS plugs myself. I run them in my OS Speed and love OS plugs, they last so much longer.
i actually had it on the richest setting it would run on and it would still idle like that.
Could it be that im using 20% nitro? i know that these engines come from the factory to run 30%
its driving me crazy. Once i get this untuned broken-in, ill throw the .28 in and give it another chance.
if i used os plugs, am i able to put a grp plug in? I heard that the taper is a lot different from the os. then again you can't always believe what you read these days.
thanks for the replies.
j8ight13 is offline
Old 08-12-2009 | 12:21 PM
  #1750
I know this sounds crazy, but I strugguled with the same problems with my MR Ninja (GRP)
The cure:
Lean idlegap and lean LSN propotionally.
Do it.... Dooo it
casevac is offline
Old 08-12-2009 | 12:47 PM
  #1751
j8ight13's Avatar
do you know how many turns out the LSN is? Someone else told me that I had my LSN to rich so it can't burn all the fuel that floods into it.
I'll give it a shot. GRPs are so much different to tune IMO. you have to make the smallest adjustments.
j8ight13 is offline
Old 08-12-2009 | 01:59 PM
  #1752
As a general rule i found:
Idle gap - smaller than you'd think
lean bottom - rich on top
casevac is offline
Old 08-12-2009 | 02:38 PM
  #1753
plus2ss's Avatar
www.raceprephobbies.com has four losr2043 rods in stock. I just ordered one. Kinda salty at 62 bucks plus 10 for shipping, but i think its worth it.
plus2ss is offline
Old 08-12-2009 | 03:18 PM
  #1754
allmost forgot; P3 or ODO97t - or a really hot grp plug
casevac is offline
Old 08-12-2009 | 03:28 PM
  #1755
j8ight13's Avatar
I have 2 extra rods right now already. Thanks for the replies. i run the P3 in there already. I was even thinking the P4 at this point. I'll close up that idle and try messing with the LSN tomorrow. It's about to rain here.
I hope i can get this to work!
j8ight13 is offline
