Like Tree2Likes
Go-Tech Engines Thread
Old 04-13-2010 | 06:39 PM
  #10441
hey im having idle problems with my go 7 port. i got everything sealed. does anyone have a good pin setting for my idle? thanks for the help
rcdude236 is offline
Old 04-13-2010 | 09:16 PM
  #10442
MassiveMods's Avatar
What sort of problems ? is the idle irratic , going up and down or is it not idling long enough ?
MassiveMods is offline
Old 04-13-2010 | 09:25 PM
  #10443
its just like wont idle very long like it starts then dies. and the venturi is open pretty far i dont wanna go much farther.
Old 04-13-2010 | 09:58 PM
  #10444
22Racer's Avatar
I usually set my idle gap at around .7 mm or .030 inch. If you don't have the Gx motor you could try replacing the o-rings in the low speed and high speed needles. The new nitrile o-rings last much longer and work great. I have some if you can't find them locally.
Rex
22Racer is offline
Old 04-14-2010 | 02:32 AM
  #10445
grizz1's Avatar
Sounds like you have the idle gap way too wide, with the bottom end needle way rich to compensate for this incorrect gap. Your motor will be too rich on the bottom, so will load up and stall when it idles for any length of time.
You have PM.
grizz1 is offline
Old 04-14-2010 | 06:18 AM
  #10446
i have the gap at .04. thats what it said in my hot bodies manuel so thats what im set at.
Old 04-14-2010 | 06:24 AM
  #10447
try following the steps on this page , it should get you in the ball park .
http://www.massivemods.com.au/produc...roducts_id=275
What sort of plug you using btw ?
Old 04-14-2010 | 08:25 AM
  #10448
Ruune's Avatar
Originally Posted by motomatt
Wow, an off-road buggy motor win's an ON-ROAD race!
How extreme was the modding of the engine?
Those top on-road engines sell for way too much.
Bone stock w/ EFRA 2072 pipe. I talked to Pato about it before. The 7-port has a ridiculous top end, whereas the 5 port has more power from lower midrange on up.
Ruune is offline
Old 04-14-2010 | 08:48 AM
  #10449
Tabushi's Avatar
Offroad engines are mostly used on GT Class. You dont see much onroad engines unless over 210 feet main straight exist, thats where onroad engines kick off.
On my local track, with about 195 feet main straight, onroad .21 engines are used by couple drivers, but engines doesnt show their habilities on that straight, GT cars are heavier than 1/8 onroad so the torque of offroad engines kicks butt.
Most engines on our championship are OS VZs, OS Speed, RB C6 (very powerful on GT), Novarossi P5 and GO.
Top 3 drivers uses OS x 1 and GO x 2 ... (1 x 5 ports and myself with the 7 port) ...
cya !
Tabushi is offline
Old 04-14-2010 | 08:58 AM
  #10450
Ruune's Avatar
bling bling...
Ruune is offline
Old 04-14-2010 | 09:21 AM
  #10451
motomatt's Avatar
Default GO banner
I'm really liking that GO Engine banner!!!!!!!
Me want!
motomatt is offline
Old 04-14-2010 | 11:12 AM
  #10452
Ruune's Avatar
I've got more coming w/ my may shipment... I'll send you one or two with the order you placed a couple of weeks ago. Also- Flywheels, clutches, etc will be available in may as well.
Dealers- I have a medium-sized shipment of GX-5Rs and GX-7Rs coming in next week, and another one due 2 weeks after that. As you already know, these are going fast- almost as soon as I unpack them. Send me your engine orders as soon as possible!
Ruune is offline
Old 04-14-2010 | 01:24 PM
  #10453
I'm runnin the os p3
Old 04-14-2010 | 02:22 PM
  #10454
What pipe for a gx3r ?
Bife is offline
Old 04-14-2010 | 07:40 PM
  #10455
I'm going to bump the thread to the top, so
the guys looking for .25 parts can get some
help.
rageworks is offline
