Like Tree2Likes
Go-Tech Engines Thread
Old 01-02-2010 | 03:40 PM
  #9691
Flanno's Avatar
Originally Posted by Gizmatron
as grizz1 said put a shim between the clutch nut and the inner bearing..DO MAKE SURE THIS IS LESS THAN 10MM DIAMETER.proper clutch shims are usually sold in packs of 3 thicknesses.5x8x 0.1,0.2,0.3..I can't tell you how often I set up clutches for guys at the track who have just slung any old washer in there.or one of those huge ones kyosho and others used to fit on old style 2 shoe clutches to stop the shoes rubbing on the bell..THE SHIM MUST TOUCH ONLY THE INNER RACE OF THE BEARING.if it is 10mm or larger it will rub on both the inner and outer races as the bearing turns and you will get friction,heat then either the washer will disintegrate or the bearing or both..slide the clutch bell and bearings on top of the shim and look at how much the crank end protrudes beyond the outer bearing.If it looks like 1mm or more you would be better to add a shim between the flywheel and the motor's front bearing.These are usually at least 1mm thick and better for large adjustments..once the crank is only protruding maybe .5mm or less check to see you have some clearance between the clutch shoes and the inside of the clutch bell.(if you don't use ventilated bells you have to guess this on feel)if there is a lot of clearance you are better to fit a thinner shim between the clutch nut and the inner bearing and thicker shims under the bell retaining screw.if it looks like the shoes are almost touching the inside of the bell then increase the shim thickness inside and less or nothing under the outer screw.I usually shim till I get a tiny amount of drag when spinning the clutch bell then remove .2mm..the difference should be obvious when you spin the bell by hand unless you fill your bearings with thick grease.(I do..)
I don't have a diagram but that pretty much cover it...
+1
Flanno is offline
Old 01-02-2010 | 08:36 PM
  #9692
motomatt's Avatar
Originally Posted by MassiveMods
This might help a bit.
Thanks Mark! Between Grizz's post and yours I think that covers it.
Thanks for taking the time to help fellas.
motomatt is offline
Old 01-02-2010 | 09:38 PM
  #9693
Hey Motto, I own a 7port Ser.#US0000135 and
a 5port Ser.#US0000218, also another 7port I
bought just before the serial numbers started.
All are modded and,after many gallons of fuel,
they are still runnin great.
rageworks is offline
Old 01-03-2010 | 09:21 AM
  #9694
vivo quevas's Avatar
Default Older GO 3 port 25
I recently purchased a new older generation GO 25 3 port for a very good price. I have read and heard the older GO motors have a rod and carb problem is that true? I read or heard the rod problem was due to a very tight sleeve so can this be helped by heating the motor up prior to starting it till the motor is fully broke in or will I need to replace the rod after 2 gallons.
I have also seen the blue head GO 21 3 port for sale in the $67 range new with shipping included are both these motors (21/25)any good for Dirtoval racing. I race on a short track top end isn't that important but smooth power from the middle of the corner off the car needs a controlled slide. Most of the guy's I race with run Dynamite platinum series or regular Dynamite's I haven't seen any higher end motors out at the track that is why I'm willing to try a older GO 25.
I had to run a picco 28 (jammin28) yesterday and it was unpredectable it would get the car loose from the center of the corner to the exit of the corner it was way too torquey motor and had a little too much topend I was having to let off early to keep the car down on entry in the corner
My car ran great with a OFNA force 28 but I have a compression leak from glowplug so if somebody has a worn out force 28 I need the head PM me.
vivo quevas is offline
Old 01-03-2010 | 10:51 AM
  #9695
bigmatt's Avatar
can anyone tell me the difference in crank rod part#s?
21-0600
28-0600
same thing different#s? one says pro one does not. The pro stronger? I noticed it was cut different on the back side.
And wich one is the new gx series rod?
bigmatt is offline
Old 01-03-2010 | 10:57 AM
  #9696
Maximo's Avatar
I am pretty sure the Go 25 is a 6 port, not a 3 port....
Maximo is offline
Old 01-03-2010 | 11:28 AM
  #9697
I don't know if it's a 3 or a 6 I haven't got it delivered to my door but these are the specs for the motor I bought i just want to know if this motor has problems and what should I look out for. Thanks
Code http://www.go-engine.com/in-products/R2500-M00HSG.htm
R2500-M00HSG
Contents 4.1cc
Maximum Power 2.8hp
R.P.M 31.000 rpm
Practical Range 6.000/35.500rpm
Bore/Stroke 17.22mm/17.60mm
Ports 3
Crankshaft 14mmSG
Carburetor 8mm
Old 01-03-2010 | 12:16 PM
  #9698
http://www.amainhobbies.com/product_...-Standard-Plug
As far as pipes to run. I think the GO 0801 pipe
would be a good choice for the track that you
run on. Also, you could try the Dynamite 086.
This pipe would also get the powerband of the
.25 where you need it for that track. If you
want to move the powerband down more than
that, try the Dynamite 053 pipe. Try out all the
pipes you can and then decide what fits your
driving style on the track. Good luck, stay off
the pipes and don't smack the boards too hard.
Old 01-03-2010 | 01:14 PM
  #9699
grizz1's Avatar
21-0600
28-0600
Hey Matt, there has been a lot of debate on the last few pages over these rods and associated cranks. I will give you the info I have, although others may disagree and tell you otherwise.
Part # 28-0600 is listed in the factory ordering lists as an RTR Con Rod. It was fitted to earlier model motors (Gen 4 and 5 I know for sure). According to measurements supplied it is not suitable for the Gen 5.5, GX motors with the slightly bigger crank pin diameter.
Part # 21-0600 is the newer rod (Pro). It is stronger and lighter and has a slightly different big end bushing size to better fit the Gen 5.5, GX Series and MG66 motors, with either the std 5.5 cranks or the newer TiNi coated cranks (GX & MG66).
Cheers
grizz1 is offline
Old 01-03-2010 | 01:44 PM
  #9700
bigmatt's Avatar
thanks grizz,glad to know I have 4 rtr cranks. I would bitch but it's the same thing here in the states.
bigmatt is offline
Old 01-03-2010 | 02:30 PM
  #9701
grizz1's Avatar
BUMMER - did you get my PM regarding upgrading to a coated crank ?
grizz1 is offline
Old 01-03-2010 | 03:08 PM
  #9702
bigmatt's Avatar
yes thank you, I emailed rick at rbmods and will phone him in the morning to see what he wants me to send. I would like to keep this original as possible. He stated that it would be 35.00 to fix,which is fine. I just don't want to do that every 4-5 gallons. The other thing that has been pointed out to me [by you and others] is that the improvements in the cranks may not make that big of a performance difference in this engine. I only paid 90.00 shipped for this engine[3 port race by rb mods] I believe they were called rippindiculous. Come to find out the guy got rid of it because low power and run times. I of course tore it apart to seal. and found he had a total shim stack of.015. That included the .003 already built in. so when I re-shimmed, boom instant power and 13+min run times. So my thinking is; the crank has been drilled and epoxy filled,but the newer cranks have been lightened and re shaped. So I am thinking it would work, new gx or mg crank. If you remember I had the same problem last year with a 5 port of his. The problem with the 5 port was it was to much engine for my talents. Man that thing had insane power. But when it came time to switch rods same thing. I ended up putting a new crank[black tin coated] in that engine. Only to have a c-clip let loose and there she went. Actually thinking back on it I think the newer designed cranck gave that 5port more top end with the same bottom.
bigmatt is offline
Old 01-03-2010 | 04:08 PM
  #9703
Ruune's Avatar
Originally Posted by rageworks
I think info like that should be made available on
the GO Engines U.S.A. web site. It sure would
help all the distributors out, huh?
Hey Runne (Trey), why don't you see if you
could get this info out to everyone? It may take
some time and effort to do, but it would also help
your distributors make you some more money.
If anyone in the U.S.of A. could get some info
from the factory for us, it should be you.
Hey guys,
Sorry for the delay in chiming in here. The holidays set us behind, but I've already provided the exploded views of the GX motors w/ parts lists to the dealers. I will also be publishing this on the USA web site.
For now, this is Go Engine USA's policy:
21-0600- Use this for all GX engines.
28-0600- use this for all other .21, .25, and .28.
Tuners and/or drivers should feel free to try experimenting rods in other engines, but this is not a configuration backed by the factory or otherwise. Damage resulting from an incorrect conrod will not be warranted.
This should settle the argument regarding measurements. Unless the factory engineers tell me otherwise, this our current position.
T
Ruune is offline
Old 01-03-2010 | 04:50 PM
  #9704
bigmatt's Avatar
trey did you get my email? do you have a con rod for a new gx or mg-66? also the email to reach you though the unfinished web site is not working. comes back domain server no longer valid. I need price with shipping to 95965 ca. would like to see some place here in the u.s. to go and buy parts.not hunt and peck method now used. get a hold of so and so if they don't have it need to order from you to get from them. and then at the mercy of what ever they want to charge. If I knew more on writing script for a web site i would help you,only because it pisses me off going there to find no info or parts availability and price. I do not want to come off as an ahole, but sure as hell do not want this going back to the way it was the last few years.
bigmatt is offline
Old 01-03-2010 | 05:07 PM
  #9705
22Racer's Avatar
I would say most of the rod problems were from a really tight motor and improper break in. It looks like the motor you have listed is a sport motor, they do not have nearly as much pinch from the factory.
Rex
22Racer is offline
