Go-Tech Engines Thread
#9676
#9680
True, I don't think his question has as much to
do with a GO engine as it does the car itself.
It is a Koyosho RTR, with a big RTR flywheel
and tall RTR engine mounts. A better answer
for him could probly be found on the Koyosho
threads. This site is getting to be more like the
RCU site every day and that sucks.
#9681
good one , my go techs never liked my mugens but seem to love my xray dirty talk if differant cars is always good
#9682
Grizz, thank you! That's exactly what I meant. I went to Google images and did a search for Go engine images. Now I can practice identifying them!
If anyone has info on even earlier generations, I'm still curious.
#9683
This might help a bit.
the Gen numbering system is something i introduced as a way to identify the different changes made to the engines. As i was asked to help develop the range it was a way for me to help categorise the evolution of the engine.
The first pic is of an early Gen 3 , the way to tell is the top of the engine has a solid finish. It had B21 on one side and the original Go logo on the other. No serial numbers yet. C 2005 to Dec 2006.
Pic number 2 is of a Gen 4 Case , change made was milled top , carb neck dimension change. exhaust port expanded. introduced SKF front bearing. New Carb , B21 and Original Go Logo still no Cerial number , head design change. C 2007 to may 2008.
Pic number 3 is a gen 5 case , Slightly larger exhaust porting side flutes. Sealed carb restrictor bolt, new case material introduced, cerial numbers introduced on right of engine then later on the left side, New Go Logo and R.21 on the other side , carb mould changed, New rod , introduced tini coating on pin and carb for some models, head design change. C May 2008 to June 2009.
Pic 4 is of Gen 5.5 case & MG case Change seals,, Carb neck changed, Coating of case, back plate coating , New carb material , seals , manufacture process , New lightened rod , new rod and crank dimensions , tini coating on pin , carb slide and crank , tolerance fit PS set from 6.5 to 6 mm , new head design from 10 to 11 fin except for MG model still 10 fin. June 2009 to present.
Some of the improvements have over lap to the dates supplied as far as internals are concerned. generally as an improvement was made and tested it was implimented.
Hoep this helps !
Cheers MM
Hoep this helps !
Cheers MM
#9684
i know this has been brought up in the pass but i cant seem to find it.
Can someone tell me what differnt header lengths do. i have a 5 port and latter this month im going to a track with a long ass back stright. apparentley
#9689
You got bearings ? or send the old girl up to me for a re-fit ?
1 mm probably a little too much play. First up, shim between the rear bearing and the clutch nut so the gear mesh is spot on (use flywheel washers for any big adjustments here), but you should have at least 1 shim between the bearing and the clutch nut. Now fit the front bearing and install the bell. Shim up the front so when it's nipped up tight you have it spinning nice and free with just a smidge of play to allow for expansion when things heat up - say .25 mm ??. Hard to be specific with a measurement, just go on feel. It doesn't want to be too sloppy though.
Yep - the rear straight at Welly is pretty long (see pic) unless they have put a jump or something in to break it up a bit. It's actually got a slight curve at the end into a big daytona sweeper, but the curve can be taken at WOT and it´slightly down hill too, so the motors get a few revs on
. A short header on the 5 Port would be sweet.
#9690
)I don't have a diagram but that pretty much cover it...
2Likes
