Go-Tech Engines Thread
#9721
today a saw a 5 port runing in a xray at my local track.
the engine runs great.... great power.
talking to the driver, he told me the run time is abou 11 minutes, that makes me so happy.... now i'm realy sure i'll run go tech this year....
does anybody knows a store where i can buy (at orlando, FL) or a online store, so i can ship to the hotel i'll be?
#9722
http://www.massivemods.com.au/produc...roducts_id=284
If he does the MG66 motors he will have the GX Series too I would expect.
Or contact Tabushi (Patricio Concha - from Chile) on this forum for GO engine details in South America. If it's to do with GO in your part of the world, "PATO" will know about it
#9724
i have just bought my first go tech engine. it is the 6 port .25. i have never had a go before, normaly i am a rossi kinda guy. is there anything in particular i should know about these engines. also does anybody have any ideal on run time, i have it is an 8ight t with a jp3 pipe. thanks for any help guys
#9725
I love the .25 6 port race engine. Once i tried, never went back to .21's in Truggy.
Mhhh in stock form it comes with NON Turbo Head, for me, best glow plugs for now have been RB #6 Non Turbo, and the Odonnel .21 - .50 medium Non Turbo plug (http://www.amainhobbies.com/product_...-21-50-cu-in-1)
Now, i just received the GO Engines Turbo Head for .25 so i will try it soon.
I dont think its anything special to advice you about the .25, just give it a good break inn and enjoy it. Right now my .25 its on 2 gallon mark, prior engine i opened after 6 1/4 gallons, replaced full internals and started using it again
Try GO 2072 pipe on .25, you will love it ...
cya !!
#9727
#9729
another +1 on the 2072 pipe here for the .25 6port. I'm not a fan of the 2072 pipe for .21 motors but on the .25, its perfect. I didn't worry about the extra shim for break in, just run it in nice and your giggling. I put a 14T bell on my losi when I had the .25 as it has so so much torque down low and the 14T made it scream in the top end and made for mind boggling top speed. Where I only dropped a couple of teeth on the spur when running a .21. Have fun with that, also found the turbo head button allowed it to rev a bit better up top.
#9732
I keep seeing this 2072 pipe mentioned, would this work well on my Go .28 3 port? I can pick one up for £47, which seems reasonable, but is about £15 more than the jammin pipes. I've only heard good things about the JP pipes, would the 2072 be more suitable?
Also, I've just got my new clutch (first new clutch, and I'm new to all this) which came with 3 sets of springs, black, yellow and silver. Which would be best in my truggy? It's not going to be used for racing, but just some general driving (field, car park, bumb and jumps etc)
James
James
#9733
JP pipes are good they are a little heavier on fuel in my testing but the 2072 pipe IMO has a good balance of bottem mid and top end power...
i used to use the jp4 on my 7 port still had good run time i was getting close to the 10 min mark with it
#9735
James
James
If you are running the new GX series motors, the 2072 is a must
We have tested all three motors in the new range now, and the 2072 pipe provides fantastic performance on all three (as well as the MG66).With your clutch shoes generally the golden coloured springs are .9 mm (soft), the silver ones 1.0 mm (med), and the black ones 1.1 mm (hard).
For the use you describe the silver 1.0 mm springs should be fine. If you find the truggy a bit sluggish or boggy off the mark, change up to the siffer black 1.1 mm springs for a later engagement and more aggressive take off.
For general use go for carbon shoes, as they wil do the job and are much cheaper than alloy ones. If you start racing alloy shoes will be better.
2Likes
Especially the 2072 pipe - awesome !!
