Like Tree2Likes
Go-Tech Engines Thread
Old 08-09-2009 | 02:13 PM
  #8191
i guess im just asking do i need just the backplate for the .21 3 port go tech to use it as a bump start
CarCrazy626 is offline
Old 08-09-2009 | 02:54 PM
  #8192
Originally Posted by malik
Traffic tickets shoot I havent had a liscens since 1999 LOL. If i am a good boy I will get it back nov of next year. I would like to see Russell get some of the MG66's that would be cool. I am going after the GX 5 port. I dont mess with the gearing in my cars. I belive they came the way they should be and for pipes, I find what I like and stick with it. I may swap out a restricter or some clutch changes if needed thats all.
Russ said he would order some but we need to tell him who many
leapinglizard is offline
Old 08-09-2009 | 03:24 PM
  #8193
22Racer's Avatar
If the backplate is just a regular backplate with no pullstart or Rotostart it is setup for a starter box. You do not need to change anything.
Like this motor
http://images.amainhobbies.com/image...0-m100sg_2.jpg
Rex
22Racer is offline
Old 08-09-2009 | 03:27 PM
  #8194
22Racer's Avatar
Originally Posted by rregl0612
I have recently started running a go 7 port and its running strong on a dyn 053.. great motor smooth with long legs and a stout bottom!
I remember a while back reading that people were dropping a head shim after break in at about 1.5 gallons.. I am almost too that point and the motor is starting to come alive. was wondering if any one has any pointers on how much to take out. sorry I dont have more time to re read a couple hundred posts.
I am running 30% on Od 99t or 97t plugs, thanks in advance
Rob
I take a shim out after a gallon or so. They come with 1 aluminum and 2 thin brass, take one thin brass out. This will be fine for 30%.
Do not confuse this with the break in shim, I never use that.
Rex
22Racer is offline
Old 08-09-2009 | 03:29 PM
  #8195
Thanks for all your help
i cant wait till it gets here....WOOT! lol
Old 08-09-2009 | 06:19 PM
  #8196
Tabushi's Avatar
Guys,
Wnyone knows of any turbo button to fit on our .25 engine ?
thanks,
Tabushi is offline
Old 08-09-2009 | 06:32 PM
  #8197
22Racer's Avatar
I have 2 new ones, but I don't like to ship outside of the Us. Last race my son ran his .25 with the turbo button and a shim added for a little timing and it was a rocket.
Rex
22Racer is offline
Old 08-09-2009 | 09:02 PM
  #8198
Rex
what are the pro's and cons? more runtime, more stress?...IDK just wondering my 3ptR is a little beast
anyone going to futaba challange? see ya there
rkhess is offline
Old 08-10-2009 | 02:30 AM
  #8199
grizz1's Avatar
Go to the previous page and click on the link in my post (second to last post), to the Massive Mods Shimming 101 article. All your questions will be answered.
Basically your changing the compression ratio. This can have good or bad outcomes depending on what else you do with nitro %, plug heat etc.
grizz1 is offline
Old 08-10-2009 | 02:36 AM
  #8200
mattwoodcraft's Avatar
after reading all that 101 info quiet a while back,i was amazed in the differance in performance of my engines and just how much easier they are to tune
mattwoodcraft is offline
Old 08-10-2009 | 05:44 AM
  #8201
What is the best glow plug to use with a GO TECH - 5 Port
RUF-VK is offline
Old 08-10-2009 | 07:04 AM
  #8202
Tabushi's Avatar
Guys,
Nice appeareance of GO Engines during stage 06 of the CACH Offroad Series in Chile - Southamerica, here the podiums :
cya !!
Tabushi is offline
Old 08-10-2009 | 08:25 AM
  #8203
Gizmatron's Avatar
Tralalala MG66 in the post from massive today..Just couldn't resist the ceramic bearing upgrade for after the run in either...
I found out from mark today that the new engines come with 2 different rods..A heavier one fitted for the run in and the spare included with the motor..these gen 5.5 rods are the new "knife edge " type ..lighter and more streamlined apparently..
I presume this is for all the new engines and not just the MG66....
Gizmatron is offline
Old 08-10-2009 | 09:31 AM
  #8204
zonda's Avatar
HI, I know people run the dynamite #86 pipe with there 5 ports but how does the GO FEMCA 0801 Exhaust Pipe run ?
reason im asking is the dynamite is still on order with suppliers and I found a GO pipe set at a good price. Almost half that of the dynamite lol
Rob
zonda is offline
Old 08-10-2009 | 10:08 AM
  #8205
From reading that Shimming 101 article this is what I gather for my application (Losi 8ight 1.0 with a GO 3 port sport,Dynamite 086, 20% nitro)
Either no shim or a .1 shim for a total of .4mm
Medium Hot plug, running an OS #8 (medium) right now. Sounds like I need to try a #7?
Any thoughts?
cLaWz is offline
