Like Tree2Likes
Go-Tech Engines Thread
Old 12-03-2007 | 01:39 PM
  #691
Jason Halvorson's Avatar
Originally Posted by will g
Im running the go 5 port standard with the dynamite 053 and i ran around 8 mins on tank with the 7.0 venturi in carb and it still puts out plenty of power but i think i need to put the turbo plug on there and make it more responsive thnx will g
will g the turbo button will increase both your run time and power across the rpm band, and maybe a change to the 086 pipe might help to tame down the bottom and make the car more drivable getting even more run time...
Jason Halvorson is offline
Old 12-03-2007 | 03:04 PM
  #692
EDIT
Old 12-03-2007 | 05:46 PM
  #693
hey guys i think i am going to get the 5 port turbo if i can afford it but not sure if i can. i have to get it from amain. What turbo plug should i get they no longer carry the OS brands and O'donnel brands?
http://forums.amainhobbies.com/index...pic,272.0.html
GRudinger is offline
Old 12-03-2007 | 05:54 PM
  #694
this is the plugs im using in my Go turbo engines http://www.amainhobbies.com/product_...oducts_id/2350...
hope this helps...if you cant afford a 21-5T maybe you may look into a 21-3 and order a turbo button for it, this would be a killer engine for a killer price...
Old 12-03-2007 | 06:01 PM
  #695
nta01's Avatar
I finally got the 053 and 086 for my 5P turbo. I was going to test it at nitro pit but it got rained out this weekend.
But I did able to run a comparison at some undeveloped home lots by my house. I started with the 053 and once I got it warmed up, I started to tune it in. The jammin broke loose on awesome damp clay. I can see it will have no problem making jumps coming off corners but it ran out of steam on long straights. Not going to be the pipe for the Pit. I also timed it. It ran out of fuel in 8 minutes. The temp was 210 and ended at 236 on empty.
I changed to the 086 same settings and the thing would bog down low. I continued to lean her out until she was able to get off without hesitation. BTW, this was 6 hours leaner on the needle. I topped it off with fuel and started to drive it. Good bottom as I able to still break loose the tires (new PL step ups). Great top end. It ran for 11 minutes, unbelievable! The temp was 205 and ended at 235.
I can't wait for the next race to see how it fairs with the other engines. Keep you posted.
Tom
nta01 is offline
Old 12-03-2007 | 06:37 PM
  #696
will g's Avatar
thnx jason appreciate the help see you on again soon thnx will g
will g is offline
Old 12-03-2007 | 06:49 PM
  #697
Rocket42's Avatar
nta01, thats sound slike a good way of testing, were you running the standard or the Turbo button, You will have no problem keeping up with anyone at the Nitro Pit. Also what buggy was that in?
Rocket42 is offline
Old 12-03-2007 | 07:25 PM
  #698
MassiveMods's Avatar
Hey All
Had a lot of people asking about our site , its up and running now
thanks for your patience
NB all international Go Engine mod engines back on line only a 2 week waiting list now
cheers MM
www.massivemods.com.au
MassiveMods is offline
Old 12-03-2007 | 07:43 PM
  #699
mugenb46's Avatar
GRudinger, hey bud, i got your PM, i think our modded 3 port would be right up your alley, pm me back if you have anymore questions on it.
mugenb46 is offline
Old 12-03-2007 | 07:46 PM
  #700
mugenb46's Avatar
Originally Posted by Jason Halvorson
got my Go 2047 pipes today (thanks Russell & Dana) boy are these pipes nice looking, and testing on all my Go engines will begin this weekend...i will report my findings...
Yes, very nice indeed
mugenb46 is offline
Old 12-03-2007 | 08:07 PM
  #701
hey mugenb46 i sent you a pm
Old 12-03-2007 | 08:09 PM
  #702
nta01's Avatar
Rocket42,
It is the turbo and I am running Jammin FTE.
Thanks,
Tom
nta01 is offline
Old 12-03-2007 | 10:19 PM
  #703
grizz1's Avatar
Hey Massive, New web site looks great. Nice graphics and very user friendly.
Now that my new 5 port is broken in I´m thinking about a turbo head button. From what I have read here there is a definite performance increase from standard plug - yes ?
grizz1 is offline
Old 12-04-2007 | 07:10 AM
  #704
free2day77's Avatar
is it possible to put a turbo button on the 3 port?
free2day77 is offline
Old 12-04-2007 | 09:12 AM
  #705
Rocket42's Avatar
Yes the .21 sized turbo button will fit the .21 3port sport engine.
Rocket42 is offline
