Go-Tech Engines Thread
#541
grizz1, glad to see it worked...i figured that was the problem...
#542
Mine only has 2 shims, 1 thin and 1 thick (i assume .1 and .2mm). It's been that way from day one running 25%-30% nitro with temps usually in the 190-230 range and i've got about 4 gal on it now..
I don't remember Russ ever saying to remove one after break in before But i think I remember someone saying before that shimming should be in the .6mm range...So more than anything i'm confused as hell now..
#544
Paradox your engine is shimmed correctly, after you ordered your engine the factory started including a extra .2mm shim. A lot of people where having problems with the break in due to the high metal pinch. If you add the extra shim during break in it makes break in much easier. After the engine is broken in the extra shim can be removed. You don't want to remove any shims until maybe after the 6 gallon mark the thin .1mm shim can be removed.
Paradoxmaker is old school he purchased one of the first 5 Go engines sold in the U.S., I have appreciated your support from day one, thanks.
#545
well it's been since labor day that i have read this thread, i sold my eight to get into electric racing. i did not have much fun racing electric, so i'm getting back into nitro
i have a turbo 7port and loved every minute of it, i can not wait to get it running again. i need to get a pipe to get more low end, is 053 pipe still the pipe to have for this motor, or has someone else found a hotter pipe to put on
#546
My 5 port was from a new batch into New Zealand. This batch of motors are the first ones to be sold here with a country code and seriel number stamped on the side of the engine mount ( ie: NZ0000015). The engine came with only 1 shim pre installed and a second much thicker shim which I am assuming is the break in shim. Any idea why the different number of shims pre installed ?
I don´t know what size the pre installed shim is as it doesn't mention it anywhere in the enclosed paper work.
On a different note. Until recently we have only been allowed to legally race .21 motors in truggy class here. As of 2008 .28 motors will be legal for racing. What are some of the veiws on .28 vs .21 in truggies. A few guys have been racing the Go tech .28 6 port in non sanctioned events and it seems a really wicked motor for the heavier truggies. I actually purchased my 5 port to use in a truggy, but now the rules have changed I might use it in my buggy and think about a .28 6 port for the truggy ???
#547
You will be most happy with the 053 at indoor LH this winter. You may even want to try the Dynamite 007 torque pipe but I think the 053 will give plenty of bottom end.
#548
satoch- thanks for the input. i will be racing at leisure hours and maybe an indoor track in iowa, so i hope that the 053 will work in iowa also, both track are tight high bite tracks
do you still have that 5 port motor, or do you have a new one. i'm thinking about getting a new motor, but wanted to HOPEFULLY
try out a 5 port sometime when i see you at lh
#550
Well I'm on my 4th gal now (i know for over a year of having the engine, thats pretty pathetic) with the same conrod, same sleeve, same piston, same bearings and the updated carb that i bought a while back...I've got backup parts for when they do finally wear out....when ever that is
#551
#552
I tried the OS 2050 on my Go 5 port and must say this is the pipe I`m sticking with.......I am averaging easy 10 minute run times per tank...I was running a OS 2060.With the 2060 my run times where around 8-9 minutes.I very,very little top end and gained more bottom....The track I run on is very large and is a on throttle track.....Oh and my 5 port is not modded and was running rich.....I believe I could still lean it out some more(many clouds of smoke)
#553
#554
#555
2Likes
