Like Tree2Likes
Go-Tech Engines Thread
Old 11-23-2009 | 12:05 AM
  #9331
Maximo's Avatar
Originally Posted by grizz1
Sweet As !!!! Glad to hear you boys are liking the new motors.
Maximo, your right on with the long needle tuning - it is stupid easy, especially with the new version GX carbs. They do seem to tune, and hold their tune very well. It all revolves around leaving that HSN alone. Once you have run the motor in, set it (barely changes from factory flush setting) and forget it .
All the new GX range are sweet performers. It seems they have the edge on the older Pro Series out of the box. The 5's and 7's are killer, plus the 3 is a sleeper. Don't be fooled by the humble 3 Port, they are a weapon with the right clutch set up
The GX7R we are running is only about 12 tanks into its life, its still very tight and nowhere near its peak yet, but even still its tuning great and making ridiculous power... The bottom end is strong, much stronger then a V-Spec and the top end is very much like my modified C6, its absolutely snarly sounding on the top end... With the long needle it has a very smooth trigger feel and gives you great control over how much power it unleashes.. So it can be driven slow and smooth very well...... I have altered exhaust port timing and angle and volume, as well as altered boost port timing and angle, as well as angle and timing on parts of the transfer ports.... The results are awesome if I do say so myself.... I can hardly wait to up the compression and fully tune it in, hopefully the weather holds and I can knock more pinch out of it and shoot a video...this is a very impressive engine to say the least....
Maximo is offline
Old 11-23-2009 | 04:15 PM
  #9332
MassiveMods's Avatar
QUICK TUNING TIP
for all new GX and MG66 Engines
www.massivemods.com
MassiveMods is offline
Old 11-23-2009 | 05:13 PM
  #9333
Thats a great tuning guide Mark. I will bookmark
your tuning advice and pass it on to anyone having
any bogging, flameout or glowplug popping problems.
(ie. MM GO Engine Tuning Guide- PG.#623 - Post #9332)
rageworks is offline
Old 11-23-2009 | 05:26 PM
  #9334
Blackie001's Avatar
Originally Posted by MassiveMods
QUICK TUNING TIP
www.massivemods.com
Yep. I followed that with my MG66 & found it quite easy. And as said earlier, 13 minute run times with a 6.5mm restrictor & Amain C2 Blue Dot. No Flame outs. No Blown plugs. Holds the tune all day. TONNES of power. No Problems!
What more can you ask for!
Pete.
Blackie001 is offline
Old 11-23-2009 | 05:32 PM
  #9335
RETRO RC's Avatar
QUICK TUNING TIP
www.massivemods.com
Just a quick question at what distance from the fuel inlet are you pinching the fuel line off as this will also effect the time it takes to cut out
RETRO RC is offline
Old 11-23-2009 | 05:44 PM
  #9336
I have 2.5 gallons on my gx7 and I took the back plate of to check out the rod play and there was no play at all. This motor is awesome.
PUDDIN is offline
Old 11-23-2009 | 06:11 PM
  #9337
About 1 cm ( or half an inch for imperially impared people ) in front of the fuel inlet to the HSN .
In theory pinching further away shouldnt make a difference but it may so in order to keep the tuning uniform keep it 1 cm away .
Cheers MM
Old 11-23-2009 | 06:41 PM
  #9338
QUICK TUNING TIP
www.massivemods.com
can't find it on the web site
dakamat is offline
Old 11-23-2009 | 06:53 PM
  #9339
69mustangbjs's Avatar
its on the main page just under the " NEW PRODUCTS FOR NOVEMBER", there's a graphic of a engine cut-a-way there...
69mustangbjs is offline
Old 11-23-2009 | 08:26 PM
  #9340
Ya, i click on it but i can't see any Quick tuning tips
dakamat is offline
Old 11-23-2009 | 08:37 PM
  #9341
Click on the writing above the engine cutaway pic,
the writing says "New GX and MG66 Tuning Guide".
If you can't find that, you'll never be able to find a
tune. j/k
Old 11-23-2009 | 08:49 PM
  #9342
aegiswa's Avatar
Questions??
Good Day-
I am in need of some pieces to rebuild my Gen 5.5 5port - as I understand it the new GX pieces will fit - who here in the states is caring the crank/rod/pin and such pieces I am looking for and for what prices?
I see 22Racer is a dealer but has no website in his sig -
Ruune is the US dist with one page website - be nice if there were some links to US dealers or a list of them somewhere - and please don't take that as a knock, it is more of an observation -
Thanks -
aegiswa is offline
Old 11-23-2009 | 10:28 PM
  #9343
Originally Posted by aegiswa
Good Day-
Thanks -
Send 22racer a pm , he usually responds failrly quickly
Old 11-23-2009 | 10:31 PM
  #9344
Maximo's Avatar
Gotta love the sound of the 2072 eh guys ? I absolutely love the scream this pipe produces ! good job to whomever put that one together !!!!
Maximo is offline
Old 11-23-2009 | 11:11 PM
  #9345
grizz1's Avatar
+1 on that I love my 2072
grizz1 is offline
