Like Tree2Likes
Go-Tech Engines Thread
Old 11-19-2009 | 11:09 PM
  #9301
MassiveMods's Avatar
Originally Posted by 22Racer
Yes a Go crank will swap with a p5 and alot of Novarossi's. I was just measuring a new Titanium nitrided crank today and noticed the lightened the backside of the counterweight a bit. Nice!
The Nitrided crank pin measured at .1966 inch or 4.9936 mm.
Rex
I wonder whos got their hands on a 66 eh ?
Hi Rhys ! i can see you hahah
MassiveMods is offline
Old 11-20-2009 | 12:52 AM
  #9302
grizz1's Avatar
Originally Posted by racer6888
Does anyone know what the top end needle should be set to in terms of turns out. I dont like the idea of set it to "flush." That is vague in my opinion and one's flush may not be actually flush. Since you only turn it in maybe a half turn at most, I'm curious if my start point is off.
What's vauge about "flush" ?? Even if you are off by a 1/4 turn from the absolute flush setting, you will be within half a turn of a performance tune on the HSN (providing you have a long needle LSN carb. Not all countries get the same LSN needles in the carbs depending on what the distributor asks for, so check this first).
No point screwing the HSN in all the way and risk damaging the needle end if you have to screw it all the way out again to get to the correct setting anyway.
grizz1 is offline
Old 11-20-2009 | 04:51 AM
  #9303
Gizmatron's Avatar
I agree..never screw needles into their seats and whats so difficult about flush..if you can't see straight get some glasses and/or use the edge of a steel rule across the top to get the needle exactly flush then use one of these http://rchardware.com/ to mark the flush position as zero...then you can find flush again in a second...
Gizmatron is offline
Old 11-20-2009 | 05:23 AM
  #9304
mattwoodcraft's Avatar
flush is flush no matter where you live
mattwoodcraft is offline
Old 11-20-2009 | 09:41 AM
  #9305
Ruune's Avatar
well, if you're an aussie... you guys flush and it spins backwards.
Ruune is offline
Old 11-20-2009 | 12:36 PM
  #9306
Gizmatron's Avatar
hahah nice one...
Old 11-20-2009 | 01:32 PM
  #9307
Blackie001's Avatar
No, No, we spin forwards..... you guys spin backwards......
Blackie001 is offline
Old 11-20-2009 | 02:21 PM
  #9308
Originally Posted by Flanno
As Matty said, "welcome to the dark side "
Whats this " Dark Side " Bizzo ? you make it sound like Darth Vader runs one in his buggy or something lol
Old 11-20-2009 | 04:43 PM
  #9309
Maximo's Avatar
Well today I had the opportunity to start driving my latest modified GX 7 port on a 2072 pipe.... I absolutely love the sound of the pipe by the way, one of the best sounding pipes I have ever run ! The engine only has 1000 CC run thru it so far, so its still fresh, but so far it runs like a champ.. Seems to have tons of power and a very nasty exhaust note...
Maximo is offline
Old 11-20-2009 | 06:21 PM
  #9310
Blackie001's Avatar
Welcome to the "Enlightened Side"!!!!
Old 11-20-2009 | 06:22 PM
  #9311
Blackie001's Avatar
Sorry Double post
Old 11-21-2009 | 05:00 AM
  #9312
uuuuuuuuum yea good one texas
the only thing spining backwards or forwards is the water draining hay ?
Old 11-21-2009 | 05:02 AM
  #9313
Mark the dark side mate dont know if you have noticed but the motor looks rather stealth an all considering its all black mate
Old 11-21-2009 | 04:51 PM
  #9314
Tree's Avatar
Those tuning dials are great, I have been using them for a few years now. Mark at R/C Hardware is a good guy to deal with.
Tree is offline
Old 11-21-2009 | 06:41 PM
  #9315
jmackani's Avatar
Default pinch bolt assembly
Does anyone know where I can get a go-1900 pinch bolt assembly or the size of the screw for the pinch bolt?
jmackani is offline
