Like Tree2Likes
Go-Tech Engines Thread
Old 09-07-2009 | 02:34 PM
  #8551
In terms of where to get the plugs in the UK..
Apex, bolton, and AMC will all have stock on weds with more to follow.
Answer-RC is offline
Old 09-07-2009 | 03:02 PM
  #8552
22Racer's Avatar
Originally Posted by mattwoodcraft
you would be gettting good run times withg 5.5 mm restrictor ?
did yo have some made or get a differnat one ..?
i have been using the 6.5 but would like to get some 6mm inserts
I made my own insert, maybe I'll make a some more. We were at the x-Fest it has a loamy surface and lap times are over 50 seconds so it's easy to run out of fuel. I still had to keep the temps up to 250 to get good mileage but it made great power.
I want to try a 5.5 w/ a exhaust reducer and a stinger reducer next weekend.
Rex
22Racer is offline
Old 09-07-2009 | 04:47 PM
  #8553
mattwoodcraft's Avatar
yea thats a big track ,my local track on pace you need to be hittin 46 sec laps to be at the pointy end of the feild ....
mattwoodcraft is offline
Old 09-07-2009 | 09:37 PM
  #8554
Does anyone know where I can get a piston sleeve and rod combo here in the states?
matrixmike28 is offline
Old 09-07-2009 | 10:03 PM
  #8555
zJatoRad's Avatar
www.amainhobbies.com
zJatoRad is offline
Old 09-08-2009 | 06:46 AM
  #8556
sky510's Avatar
hi guys,
i was running my go 5 port last weekend at the qualifiers seems to be running pretty good, to much fish tailing but it was fun need to learn throttle control anyhow at the mains it started just fine and running strong ath the 4 min time( 20min main) motor quit at first i though I ran out of fuel already but it was not the case, started it up again and it quit after several laps, refueled and change glow plug it did cut out again and again so I decided that was it for the day. I did shorten the LSN like grizz suggested and my needles are 1.5 high and about 2.5 LSN. Then next day just around the drivewayjust testing was is going on with it change plug airfilter and still cutting itself out specially on wot richen the HS to about .5 from flush same thing any suggestion?
thanks
sky510 is offline
Old 09-08-2009 | 07:46 AM
  #8557
bigmatt's Avatar
Originally Posted by sky510
hi guys,
thanks
sounds like you have an air leak.Either around carb or carb needles or back plate.
bigmatt is offline
Old 09-08-2009 | 08:34 AM
  #8558
yea mate i think i will have to agree it does sound like an air leak , i have tried the shorter needles but IMO prefer the longer needle on the lsp , on and around the carb where it seals to the crank case i use 2 orings ,
Old 09-08-2009 | 02:26 PM
  #8559
I meant anywhere I can get a 5port piston/sleeve and rod IN STOCK right now????
Old 09-08-2009 | 03:56 PM
  #8560
bigmatt's Avatar
special-rc on ebay. will take about 5 days to get to you. also try 22 racer, fx hobbies in Canada. If your waiting for amain to have them ,you have a long wait. Russ Jones our U.S. distributor just has no business being our go tec rep. No parts, no new engines,nothing. FX Racing Hobby Inc, thats the shop in canada.
bigmatt is offline
Old 09-08-2009 | 04:53 PM
  #8561
if you get stuch order from massive mods mate , and air bag it over if you have no luch any where else ....
when i need something i will order from any where , i guess we are very lucky to have mark here in australia
Old 09-08-2009 | 05:39 PM
  #8562
bigmatt's Avatar
You have no idea how lucky you are to have massive mods.
bigmatt is offline
Old 09-08-2009 | 06:15 PM
  #8563
Poltro's Avatar
Hi all!
I was just wondering if someone could tell me how to remove the carby form my go 3ptR. I completely removed the screw that hold the carby but it wont move.
Also how many shims do you suggest for 25% and 30% nitro?
Thanks!
Poltro is offline
Old 09-08-2009 | 06:35 PM
  #8564
smokinu's Avatar
Originally Posted by Poltro
Hi all!
Thanks!
you need to check head clearence i am not sure for the 3p r motor
but to remove the carb you have to just get it unstuck i use a wash cloth and then grip it with some plires and twist and pull.
smokinu is offline
Old 09-08-2009 | 06:44 PM
  #8565
22Racer's Avatar
Hi all!
Thanks!
Loosen the pinch bolt screw a couple turns, lightly tap on the screw until it pushes the pinch nut out the other side, take all the way out. Turn the carb the direction that the remaining part of the pinch bolt is. (if it's on the right turn the carb right) it should break loose fairly easy, be careful not to overtighten when putting back together.
For 30% I use one silver and one thin brass shim, they come with 2 brass. You have to be very careful not to get dirt in the motor when taking the head off.
Rex
22Racer is offline
