Like Tree2Likes
Go-Tech Engines Thread
Old 05-27-2009 | 05:35 PM
  #7006
mattwoodcraft's Avatar
i have a 3 port moded but i will be running it in , my mate has a 3 port and as far as im concerned was unable to see alot of differance between the 3 or 5 port on the track , the 3 port was hauling some cerious ass .... he had the 2072 pipe on it
i cant wait to be running mine
mattwoodcraft is offline
Old 05-28-2009 | 07:25 AM
  #7007
sky510's Avatar
@ grizz
I did the fule tubing on my needle (because they are worn out) it work great and fits snug. I'll do this for all my motors
thanks for the tip
sky510 is offline
Old 05-28-2009 | 08:29 AM
  #7008
tagalong_74's Avatar
so guys just switched to the 053 from a 007 and wow. Tons more top end power and just all around awesome. Cannot complain. Will let everyone know how it goes when i run it on saturday.
tagalong_74 is offline
Old 05-28-2009 | 12:15 PM
  #7009
Just got through running my 5 port. Temps were a little warmer than I would like upper 280 low 290. Engine has less then a gallon on it. LSN is 1/2 turn in from flush. HSN is flush or slightly above. Engine was alittle sluggish in transition form idle to WOT. Is this normal?
Dummer40 is offline
Old 05-28-2009 | 12:28 PM
  #7010
vyt666's Avatar
Originally Posted by grizz1
Probably a little too lean on top. Long LSN settings - HSN .25 to .5 max in from flush. LSN 1 to 1.5 in from flush.
Read back on this thread a few pages about how the long LSN carb tunes. Basically set the HSN at .25 turns in and leave it alone. Do all your tuning with the LSN, maybe tweaking the HSN a screwdriver width as a last adjustment to get the last 15% of the rev range nice and crisp.
The 086 pipe suits the 5 Port better then the 053, but it will run fine with this pipe.
Don't mess with the HSN needle.
It is only the long 1.6" LSN needles that can throw people off when trying to tune the GO motors.
If you read the explanations and follow the instructions on the last few pages of this thread, your motor will run fine on the long needle. If you prefer a more traditional style of engine tuning (easier for most to get right I feel), then shorten the LSN down to 1.42" and away you go. With this needle fitted the GO motors will tune just like any other nitro motor.
i tried setting the needles to its factory settings and start tuning again and have found the sweet spot,thanks again for the help
vyt666 is offline
Old 05-28-2009 | 12:47 PM
  #7011
2fst2c's Avatar
I'm wondering how an ofna 063 pipe would work on a 7pt Go? It's supposed to be a mid to high pipe. I just got a 0801 for my 5pt but I have 2 buggies I like set up a little different with different motors for obvious reasons and happen to have a 063 laying around. My other pipe choices I have are a werks 2013, and a THS 8016H. Looking for the best run time because these motors have plenty of power all around in my opinion. Thanks!
2fst2c is offline
Old 05-28-2009 | 02:26 PM
  #7012
grizz1's Avatar
If it has less then 1 gal on it the motor will still be tight - hence the higher temps and the sluggishness. Don't lean it out too much (although the settings sound OK) until you have another 1/2 gal through, or the majority of the metal pinch has gone.
Not sure on the 063. The best pipe for the 7 is an 053 or the GO 0801 you already have. Of all the pipes the 0801 will give you the best economy on the 5 or 7 Port. You might like to look at the new GO 2072 pipe for your 7 Port.I hear it is very good on all the Pro motors. Give the 063 and the 0801 a whirl, and let us know how they compare.
grizz1 is offline
Old 05-28-2009 | 02:35 PM
  #7013
JEB21's Avatar
Tore up my rubber gasket between the engine and header on my 5 port. Can't find a Go one in stock. Aren't those things pretty universal? I'm assuming most will fit???
JEB21 is offline
Old 05-28-2009 | 02:51 PM
  #7014
22Racer's Avatar
Yes, any .21 size gasket will work.
Rex
22Racer is offline
Old 05-28-2009 | 02:55 PM
  #7015
JEB21's Avatar
Rex
Thanks Rex. Engine is running great. I've got just over 1/2 a gallon through it and its staying between 240-260 consistently with a nice plume of smoke. Looking forward to losing the pinch and getting the thing fully broken in.
I'm actually impressed with the power it's putting out already!
JEB21 is offline
Old 05-28-2009 | 03:35 PM
  #7016
vhb
Default GO Newb fuel question...
Just received my new GO .21 5p and am readying for breakin. I run Byron Race 20% in my stock Associated .28 and it works great for me. Looks like most run 30% in the GOs.
I would like to run the same fuel in both cars but if the 30% is the way to GO then let me know and why if you could.
All input as far as fuels for the GO would be appreciated!
tks,
vhb
vhb is offline
Old 05-28-2009 | 04:11 PM
  #7017
bigmatt's Avatar
tks,
vhb
I use sidewinder 20% worlds in my go tec's 5-7 port engines. after break in I removed a shim. actually 2 shims, as I put in the extra shim for break in. I think mark from mmods uses 20% also. how do you like the byrons? that is what I am thinking of switching too.
bigmatt is offline
Old 05-28-2009 | 04:23 PM
  #7018
hey matt byrons fuel is great fuel. Tons of power and no difference from any other brand. I used to run odonnel but because of the spike in prices last year i switched and went to byrons and havent noticed a lick of difference
Old 05-28-2009 | 05:58 PM
  #7019
vhb
I love the Byrons, I tried the O'donnel and the Nitrotain and have much better feel/tuning/smell with the Byrons.
So I think I will follow your lead and break er in with both shims on 20% then remove both of them and continue on...
Thanks!
vhb
vhb is offline
Old 05-28-2009 | 11:35 PM
  #7020
grizz1's Avatar
Originally Posted by DRRC
I would like to know which of the Go engine is the best for 1/8 buggy racing
I have the 7pt and it is very fuel efficient can last 10plus minutes, the 5 port has tons of torque
How is the 3port compared to these two?
Talking standard motors - the 3 is a nice buggy motor. It is very linear in it's power curve, so is easy to drive. With the 0801 pipe fitted it is also very economical giving 10 min run time when fully broken in no problem.
The stock 5 is perhaps a little too much for a buggy. The modded 5's are very powerful, but most are modded to be a little softer on the power delivery down low so suit a buggy better.
7 Port is a wicked buggy motor - which you probably already know as your running one
grizz1 is offline
