Like Tree2Likes
Go-Tech Engines Thread
Old 06-24-2008 | 12:50 AM
  #3346
grizz1's Avatar
Originally Posted by Poinas2
This would be the case if you are running the stock 8mm venturi. If you go smaller to seek longer runtime you might need to adjust accordingly. I found out that my 5p + JP-3 with 7mm insert does not clear out untill you have HSN in about 1/2-3/4 turn. So in case you change the venturi you should consider the effects it has for the tune.
Thanks Poinas, We were talking "stock" settings as asked for by 1fast guy. Your point taken though, well worth remembering
grizz1 is offline
Old 06-24-2008 | 04:31 AM
  #3347
I just ordered a PTM 5 port. Do I need to ad a shim to run Byrons Gen 2 25%? And what restrictors come with it? It will be in my truggy for a very short period till a buggy I am waiting for to be released. When I put it in the buggy what restrictor should I use, and which one should I be using now in the truggy?
malik is offline
Old 06-24-2008 | 04:38 AM
  #3348
I believe you should get the info from PTM about the shimms. GO are OK for 25% and the additional shim in the box it for during breaking in the engine.
Unless you bought a restrictor kit I believe it comes standard with the black 8mm and it's just fine with it. You can go to 7.5 or 7mm with it to gain some on the mileage if you like. For the truggy I'd leave the 8mm on or go to 7.5mm
Poinas2 is offline
Old 06-24-2008 | 04:47 AM
  #3349
Originally Posted by grizz1
HSN flush and LSN 1 1/2 turns in from flush will get you running every time. This is always a good starting setting if you loose the tune completely for some reason.
Lean the LSN from here until you get a nice steady idle and you will be sweet.
LSN will probably end up about 2 1/2 turns in from flush, maybe a little more for full race tune depending on fuel, pipe etc. HSN you don't want to go more than about 2 hours in from flush. Go's like a fat top end and a lean bottom end
thanks bro and what kind of runtime are you getting with those settings
Mo Denton is offline
Old 06-24-2008 | 11:11 AM
  #3350
i would just like to say i love my go engine but what i dont like is the carb i have the sport 3 port and the carb was a tuning nightmare the motor would run great and then lean bog on the bottom so after reading all the different posts on here i sealed up the needles with green slime ran a tank and lean bog still richened the bottom a half turn great smoke for a minute then leaned out richened another half turn great smoke and power for a minute then leaned out so i swapped the carb with the one from my os motor and it runs reliable and great holds a tune and i could not be happier i would just like to know were do you get the correct low speed needle if in fact i may have gotten one of the bad ones as i would like to make the carb that came with my motor work with my motor
teamreidy is offline
Old 06-24-2008 | 11:58 AM
  #3351
grizz1's Avatar
Around 7 mins depending on track conditions. This is with a pretty conservative tune, not full race tune.
I did run a 7mm restrictor like Poinas2 suggests in my 5 Port T, and at the end of a six minute heat had 1/3 of a tank left, so looking at around 9 min total. Again this was not full race tune. I believe some of the gun tuners are getting 10 min + out of the 5 and 7 ports !! (not me though )
grizz1 is offline
Old 06-24-2008 | 02:06 PM
  #3352
mugenb46's Avatar
11.15 this weekend on the 7 port turbo 5 ports are right there with it.
mugenb46 is offline
Old 06-24-2008 | 02:43 PM
  #3353
sachoppers's Avatar
Is it the hsn..that was giving most peps the tunning issues?
Also what part # needle was it being replaced with?
sachoppers is offline
Old 06-24-2008 | 03:14 PM
  #3354
it was the lsn that was giving me issues. and i replaced the entire carb with an os carb.
i was looking for the correct lsn to replace the one i have in the origanal go carb.
Old 06-24-2008 | 04:03 PM
  #3355
sachoppers's Avatar
LSN read back threw the posts..
One other thing do all three go motors use the same crank..and when would be a good time to place it?
Old 06-24-2008 | 05:13 PM
  #3356
mugenb46,
The 08 model Go's have rectified the carb issues as you mentioned earlier, are these the Gen 4 or 5 carbs?
Also re getting 11.5 mins run time with 7 port is that in a buggy or truggy?
Is that stock or modified engine?
Could you also please elaborate re fuel, clutch set up, pipe combo, restrictor size and EPA settings you have been using?
Jesussaves is offline
Old 06-24-2008 | 06:39 PM
  #3357
mugenb46's Avatar
Originally Posted by Jesussaves
mugenb46,
i would call them gen 4, they have the same design, but the engines available in a week will have the old lsn, this should clear up any hsn issues, it allows a braoder tunning window allowing more fuel to be adjusted with.
this engine is being ran in a xray 808, by team driver Dan Reino, i have been out of town every weekend all summer doing big cars, but him and Jackie Woodard are both on my speed dial, they both run xray, and jackie runs truggy, using a PTM .25
the 7 port is not fully modded, at this we are just going a little at a time trying a few things that may roll over into the full modded PTM engines, so far we are liking the results.
we are running byrons currently but i stongly prefer Tilted 30%, with a P3 plug and the GO FEMCA 0801 pipe, and innovative designs 6mm carb insert, and Dan is running the stock clutch shoe set up that the car came with, all 1.0 with alum shoes. i don't have a clue what his epa's are on the radio, sorry
I will get Dan to post on here in the morning and give his opinion on the feel of the engine to this point, if there is anything he doesn't like he will state it, he is very honest on his input of the engines i provide him, he has done 90% of our testing on the PTM GO engines.
mugenb46 is offline
Old 06-24-2008 | 07:12 PM
  #3358
Does anybody know if GO is taking care of the lsn problem or am I expected to buy a new one myself? I was pulling my hair out with this problem had many others helping over 2 race days. Finally after catching up on this thread, I pulled out an old vspec carb and have had zero issues now
clebo3 is offline
Old 06-24-2008 | 07:16 PM
  #3359
mugenb46's Avatar
email russel at racefactor ind, and let him now, i do know for a fact the new engines are going to have them in them, and seperate needles will be available.
mugenb46 is offline
Old 06-24-2008 | 10:07 PM
  #3360
grizz1's Avatar
Oops - posting error
grizz1 is offline
