Mugen MTX-3
Old 01-02-2003 | 03:20 PM
  #1501
Thumbs up New shock mounts
Developed my Microtech racing in the UK to allow a wider adjustment of shock angle, the hole radius is also formed to maintain the same ride height for each hole. You do have to mount the rear body post on the opposite side, but this then allows all your MTX2 shell to fit.
Available world wide from www.microtechracing.com
Please mention where you saw them!!
FRONT
REAR (notice the cut rear hubs, camber link angle, this will be a rubber tyred car)
Cartman is offline
Old 01-02-2003 | 03:31 PM
  #1502
black-knight's Avatar
i had a Trinity Nitro car a while back...and the 1 thing i hated on that car was the receiver box!... it's too tight and restrictive, the way in which it attached the the reflex was poor too, it was simply a pain!.
The standard mtx3 setup is way better in my opinion.
black-knight is offline
Old 01-02-2003 | 03:34 PM
  #1503
Default Re: New shock mounts
Originally posted by Cartman
Developed my Microtech racing in the UK to allow a wider adjustment of shock angle, the shock radius is also formed to maintain the same ride height for each hole. you do have to mount the rear body post on the opposite side, but this then allows all your MTX2 shell to fit.
how r u going to race the pictured car...it's way too clean! it would be a pity to get it dirty! lol
Old 01-02-2003 | 03:43 PM
  #1504
In the uk we get WET weather so Mugens cover is not good enough
the car is clean as its never been run its or wet winter here (even in summer we get rain!!!
Cartman is offline
Old 01-02-2003 | 03:57 PM
  #1505
Default Trinity receiver box
Hi Mark,
Where's the best place to get a Trinity receiver box in the UK?
No suppliers in Ireland stock them or will get me one!!!
Many Thanks
click, dublin is offline
Old 01-02-2003 | 04:01 PM
  #1506
Hi
I got mine from local shop who ordered it in but try www.microtechracing.com he will get one.
helgar import them, but i think CML do the kfactory one which is the same.
either way Kev a microtech will sort you out
Cartman is offline
Old 01-02-2003 | 05:05 PM
  #1507
Default RE: New Shock Mounts
That rear mount looks trick, but the front mount looks like it's just begging to get broken off in a crash.
tekrsq is offline
Old 01-02-2003 | 05:29 PM
  #1508
Jack's Avatar
Originally posted by hurhur
hmmm...i cant find this part number on kfactory's website. Any idea where i can see it in the internet?
so hur hur.. u got your MTX 3 yet??
managed to get it running yet??
how is it handling?
Jack is offline
Old 01-02-2003 | 05:33 PM
  #1509
Manticore's Avatar
Default Re: RE: New Shock Mounts
the tall shock mounts are useful if you run rubber tires.
Manticore is offline
Old 01-02-2003 | 05:43 PM
  #1510
Default Re: Re: RE: New Shock Mounts
Why?? What difference would the height of the tower make?? Or is it just because of the extra adjustability??
tekrsq is offline
Old 01-02-2003 | 10:35 PM
  #1511
Michael_T's Avatar
Default Re: Re: Re: RE: New Shock Mounts
I think it allows for a more linear suspension setup. The MTX3 has aggresive progressive suspension (who said I can't rap )
Why don't we guys post all the problems associated with building/running the car and we'll stick them up on one of my sites? Do the oldies remember this with the MTX-2 thread on the hpiracing site?
Michael_T is offline
Old 01-02-2003 | 10:51 PM
  #1512
Manticore's Avatar
Default Re: Re: Re: Re: RE: New Shock Mounts
NR, here you go
first hint
brake pad
exame if the backing metal plate is perfect flat. otherwise you need to twist the plate to ensure the plate is close to perfect flat. use rubber glue to stick the pad and plate together and use rubber hammer to hit the combo to ensure the pad sits properly on the plate.
second hint
slope on rear arm
The kit comes with two alloy shims to remove slope there but they are just about too thick. Use electric motor telfon shim to do the job. one piece on each side will do the job.
Old 01-02-2003 | 11:32 PM
  #1513
Michael_T's Avatar
Default Re: Re: Re: Re: Re: RE: New Shock Mounts
NR, here you go
first hint
brake pad
second hint
slope on rear arm
Kool,
Manti, I didn't see any extra alloy shims come with the kit for this?. Are you talking about the shims that are included so you can increase/decrease upper arm camber on rear hubs? If I recall, there is one thin and one thick one and standard setup requires to use both of them
Old 01-02-2003 | 11:33 PM
  #1514
Manticore's Avatar
Default Re: Re: Re: Re: Re: Re: RE: New Shock Mounts
Kool,
I think so
Old 01-02-2003 | 11:50 PM
  #1515
Michael_T's Avatar
Default Re: Re: Re: Re: Re: Re: Re: RE: New Shock Mounts
I think so
Kool, u had me worried.
I only had 11 screws left over.. but no shims
