Mugen MTX-3
Old 12-17-2002, 11:50 PM
  #1351
Manticore's Avatar
Originally posted by Novarossi
Gotta love Manti and his attitude
I love you too !
Manticore is offline
Old 12-17-2002, 11:53 PM
  #1352
dtm
dtm's Avatar
Originally posted by Manticore
majority of the dudes here will not apprecaite your priase of snake here ! better keep it some where
Snake Rulez.....Snake rulez!!!! is this a shortcut method of gaining popularity!!??!!!
dtm is offline
Old 12-17-2002, 11:54 PM
  #1353
Manticore's Avatar
hahaha you rctech goblin !!
Old 12-17-2002, 11:58 PM
  #1354
dtm
dtm's Avatar
I'm "ill" at home right now...so I thought I'll spend the time stirring a few things up!!!
dtm is offline
Old 12-18-2002, 12:01 AM
  #1355
Manticore's Avatar
damn, go back to work goblin !!
Old 12-18-2002, 01:08 AM
  #1356
sparksy's Avatar
Trader Rating: 14 (94%+)
Manti secretly loves the snake.... but gpm doesnt make options for it....
See he has snake parts on his mtx-3.....
When will we see GPM parts for the 3 Manti?
sparksy is offline
Old 12-18-2002, 01:30 AM
  #1357
Manticore's Avatar
reveal of my secret again !!!
Old 12-18-2002, 02:32 AM
  #1358
hurhur's Avatar
Its an open secret!
hurhur is offline
Old 12-18-2002, 10:09 AM
  #1359
eddiethefish's Avatar
GPM for Mugen MTX-3? What is GPM?
eddiethefish is offline
Old 12-19-2002, 08:30 PM
  #1360
Manticore's Avatar
GPM is an option house somthing like kawahara but quality is thumb down.
Old 12-19-2002, 08:32 PM
  #1361
dtm
dtm's Avatar
And I thought it was GP for Manticore!!!
dtm is offline
Old 12-19-2002, 08:38 PM
  #1362
Manticore's Avatar
that is a very bad coincident
Old 12-19-2002, 11:09 PM
  #1363
RClover's Avatar
Default Centax Clutch Assembly
4)Put a drop of high temp oil (Racer's Choice - Hy-spin #7015) on each actuator and where it will ride on the flywheel. If the clutch uses a return spring on the actuators, use it. The clutch will disengage faster if this spring is in place. (PD note: this oil tip works).
5)Smear a coat of high temp oil on the rear of the pressure plate and slide it on next followed by the shoe with the spring cup already pressed in firmly. Spin on the adjustment nut until 1-2 threads are showing on the end of the flywheel nut.
Manti:
This is an extract of an article posted in the V-1-R tread earlier.
Can i replace 'High Temp Oil' mentioned as above with 'High Temp Grease'? Its sinthetic based and is Red in color. I found this from a friend who runs a workshop.
BTW, what is 'Actuator' mentioned in the above?
cheers...
RClover is offline
Old 12-19-2002, 11:36 PM
  #1364
Manticore's Avatar
Default Re: Centax Clutch Assembly
Manti:
cheers...
I think he is talking about flyweight (actuators) but I prefer not to as this flyweight is teflon which is self lubricated.
I used to use ronnie grease between each race day but the first run will make the grease disappear. I end up only lubricated it when I remember it . However, but for serious racer, I suggest you to lub it more frequent
but proper installation of the clutch will actually make the trust bearing lives longer.
Old 12-20-2002, 03:21 AM
  #1365
chookgb's Avatar
Trader Rating: 26 (100%+)
Cool
hi i am just wondering has anyone tried rear springs on the front of an mtx-2 or mtx-3 if they are the same colour do they work out the same stiffness ? as on both cars to get the ride height correct, at times there is no tension on the spring at all any thoughts would be appreciated,also when securing the lock nut on the piston in the shocks is it advisable not to tighten the nut fully and allow the piston to rotate or do most people lock the nut fully locking the piston in one place
chookgb is offline
