Mugen MTX-3
Old 01-17-2003, 12:24 PM
  #1651
can some one post pictures and a list of the sato parts please!!
thanks
Cartman is offline
Old 01-17-2003, 04:52 PM
  #1652
Manticore's Avatar
Originally posted by Corse-R
Ouch! that hurts. I've smashed front arms, uprights and the usual hardware. But the only two times I got T-boned was hurted seriously.
On the attachment, you will find the results of being boned by a team mate on the virgin run of my Xray Evo 2. At least let me to run 4 full laps at interesting pace.
Broken A-arm, shock parts, rear shock tower, bent the shock rod, bent the universal and other things that I've discovered at house due to the faulty handling.
that hurts !!
Manticore is offline
Old 01-18-2003, 08:27 AM
  #1653
manticore do you know if the front wheels are overdriven with the internal gearing of the mtx-3
ive heard the v1r is internally overdriven
jason102276 is offline
Old 01-18-2003, 09:24 AM
  #1654
dtm
dtm's Avatar
................ Seems that Manti lost at least one time an one-way outdrive and needed to replace it...
Nah....I'm sure he simply had a few spares lying around...considering he never use to run his Xray anyway!!!!
dtm is offline
Old 01-18-2003, 11:53 AM
  #1655
InitialD's Avatar
I don't think so. Front and rear internal gearing is 2.52. So using same frotn and rear diameter foams will give you an overdrive of 1.
I believe the V1RR lola version comes with an overdrive pulley. Instead of the stock 27T side pulley, a 25T is also given. i was told optional belts are also supplied for the use of the 25T. I believe when you run with the "overdrive" 25T pulley, you need to run a split of approx 5 mm (front smaller than rear) in order to give you back a 1:1 overdrive.
InitialD is offline
Old 01-18-2003, 12:41 PM
  #1656
Corse-R's Avatar
Checked it at 'eyeball' and seems to run 1:1 not overdriven nor underdriven. But calculations can made, anyone can post the number of teeths of the different pulleys? (rear diff - pulley, rear center - front center, front pulley - oneway?).
My testing day is ruined by a damn fog and a 96% of rel humidity.... if this continues.... need an MTX3 dose.... need an MTX3 dose...
Corse-R is offline
Old 01-18-2003, 06:00 PM
  #1657
snoopy's Avatar
This is the g/box of the MTX-3
19----------24
48--19 16--32
Rear Front
snoopy is offline
Old 01-18-2003, 06:02 PM
  #1658
snoopy's Avatar
Damn,
lets try again
19-------------24
48-----19 19------32
Rear Front
snoopy is offline
Old 01-18-2003, 06:04 PM
  #1659
snoopy's Avatar
Stupid thing......well i hope most you get it...
snoopy is offline
Old 01-18-2003, 06:18 PM
  #1660
AMGRacer's Avatar
Actually the V1RR even with the 27T side pulley has a very small front overdrive. I think it is around 0.5 or 0.9%. You will find most of the belt cars have this "feature" to make the car slightly easier to drive. This is another reason why the NTC3 seems so free compared to the belt drivers.
AMGRacer is offline
Old 01-18-2003, 08:31 PM
  #1661
InitialD's Avatar
AMGRacer, can I know how you arrived at such overdrive figures of the V1RR with 27T side pulley?
Front drive ratio = 32T / 18T x 27T / 19T = 2.5263
Rear drive ratio = 48T / 19T = 2.5263
Both front and rear drive ratio is exactly the same. Assuming both front and rear tires are equal in diameter (which they are if you buy them stock), how does that make 0.5 to 0.9% overdrive?
InitialD is offline
Old 01-18-2003, 08:34 PM
  #1662
Manticore's Avatar
you better study your serpent instead of bashing here!
Old 01-18-2003, 08:42 PM
  #1663
InitialD's Avatar
Manticore, I do not see anything wrong with my post here. Can you stop your personal attacks? I know my Serpent very fine thank you. If you do not have anything nice or useful information to post, I suggest you should refrain from posting. That is all I ask.
The forum is free and I think I can choose to post anywhere so long as it is a valid question and give valid answers. I'm learning too and if what I posted was wrong, I would like to know and I do not mind to be corrected. Thanks.
InitialD is offline
Old 01-18-2003, 08:43 PM
  #1664
Manticore's Avatar
thank you for your comment. Manticore is still Manticore. Now you can go away kid.
Old 01-18-2003, 08:44 PM
  #1665
Manticore's Avatar
By the way, no one here wants to know how good is your snake !!
